What are they worth??
Message Reverse Sort Order
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: What are they worth??
    Posted: 25 May 2010 at 11:14pm
D15 is worth that if the engine is the 160 CID....if the remaining rods are any good.
ALLIS EXPRESS!
This year:
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 9:42pm
Had a few email replies looking for some tractors and here is what I found....I cant afford them all so I'll pass them on if you want....D15 with a hole in the block....has a loader, newer rear tires...dont know much else and havent seen it yet....probably 700 bucks cash will buy it the guys says....a WC...no clue if unstyle or styled....has a plate welded on the block....but it runs....sounds strange but Im gonna check it out...900 obo.....a few WD's for 1500 or so with an without loaders/trip buckets....I think both were wide fronts....were a bit more money with the loaders.....what do you guys think these are worth??
