LOOKING FOR ,7060 CAB PARTS
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: LOOKING FOR ,7060 CAB PARTS
    Posted: 25 May 2010 at 7:59pm
HELLO
     I AM LOOKING AT BUYING A 7060 AND NEED A FEW ITEMS TO GET IT WHERE I WANT IT, SO I AM LOOKING TO SEE WHAT PARTS I CAN FIND. I AM LOOKING FOR 2 CAB GLASSES, 1)LEFT SIDE GLASS  & 1) REAR GLASS I DON'T REALLY NEED THE LOCKS BUT WOULD LIKE THE HINGES.
      I WOULD ALSO LIKE THE AIR FILTER DOOR AND LOCK LATCHES  THAT HOLDS THE CAB AIR FILTER IN THE CAB.
      I MAY ALSO NEED THE SKID PLATE THAT PROTECTS THE HYD. PUMP.
        THANKS FOR ANY HELP
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 8:52pm
Anderson Tractor Supply in Bluffton, Ohio, 800-603-8141, should be able to help you.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 10:05am
There is a serial number break on the air filter retainer and cab glass and hinges.  Maroon belly tractors are different from black belly, but be sure to check what you are getting as some tractors were repainted the wrong color over the years...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 10:57am
Cook Tractor in Clinton, MO and Northside Salvage in Red Bud, IL should have what you need.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
armandjones82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote armandjones82 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 8:24pm
If you are still looking in to some parts, like the air filter, why not try to use some branded parts like k & n and the like. They are available either in your area or in the net. Try to find that one and see what would fit your vehicle's need.
Edited by armandjones82 - 23 Jan 2011 at 8:51am
