Looking at an N6. The good, bad, and ugly??
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Topic: Looking at an N6. The good, bad, and ugly??
    Posted: 01 Oct 2016 at 4:47pm
Looking at an N6. Don't know a lot about combines. Always hired it. Any ideas thoughts experiences to help me decide if an N6 will be suitable machine for 100+ acres of corn and a few acres of beans. Norms book says 7800 built. There must have been fairly decent units?
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 4:50pm
Top of cab has KS LTD. I'm not sure what that stands for unit has 3600 sepetater hours.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 6:50pm
There are people that know more than me about it but it depends on price and if its had parts put on it. This sounds like a later model so the rpms should of been turned down on the engine. I know a 426 in a combine is getting tired at those amount of hours. LTD was just a model that had the most popular options on it.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 7:38pm
You will be happy as long as it has been taken care of.  We ran an N7 for years, and still have it as a backup for my uncle.  They do go through parts, not excessively but the bearings in my opinion are light for the combine.  a hundred acres would be cake for it, just do a little work on it in the off season, and you will be fine.  I cannot say specifically on the 6 what are problems, but it shouldn't be too much different than the 7 for week points.  KEEP IT GREASED, especially the rotor coupling!!!   With those kind of hours, it should have some repairs, so see what has been done in the last 1000 hours or so
Still in use:
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 8:59pm
I just spent the afternoon in my N6 trying to finish up my wheat harvest. I absolutely love it. Darrel
8050/8030/185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8050/8030/185 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 9:11pm
I have an N6 and have for years. Don't get anything older than a 1983 marked with Series 3 and newer. The earlier N6 had more than their share of problems. Mine is a Series 3 1983. It has been well cared for and never left outside. As long as the engine has gotten the maintenance that is needed including the bearings and bolts on the rods changed the engine will be in good shape and original. Most of the earlier N6 were known to break bolts and throw rods. And the later ones had the newer throat and had many more heads that fit the machine. The earlier throat only liked the N head. Find out the year and service records. That will tell you a lot about the machine you are looking at. Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 9:16pm
Darrel can you give me more info on yours? What year? How many hours? What have you done to it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 5:11am
At 3600 sep hrs, it should have had a new cage installed and may be in need of a second cage. At more than 10 acres per sep hr, it may have harvested 40,000 acres by now. Think about that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 9:37am
Mine is a 1984 model. I first bought it last year. I would not buy one that is not at least a 1983 or newer either. I did about 550 acres of wheat with it last year, and a little over a thousand this year. The only things I've done to it is a cab power solonoid last year, and a clean grain elevator drive belt this year. (Ooops, forgot, one grand into air conditioner last year after I got it) Paid 5 grand for the machine; came with 24 foot rigid auger head and 13 foot dummy head with a sund picker on it.
   I bought it from a neighbor to us where I grew up. I was working at the implement dealership where he bought it when he bought it, so I did the pre-delivery on it. I can't remember how many hours were on it when he brought it in for a re-build, but I did that, too. Put in a sunnybrook concave, new seperator and thresher bars on the rotor, new feed chains and sprockets, elevator chains, and I can't remember what else. I do not know if rods and mains have been done or not. Has 3000 plus engine hours on it. Has no seperator hour meter. The cage is not too bad, but there are a few thin spots.
    This combine has sat outside more days in the year that I've owned it, than it did in the prior 30 plus years of its life. The guy always kept it inside, and looks good accordingly so. The PO re-tired about 5 years prior to me buying it, so it sat inside, un-used during that time. My son did an absolute complete detailing of the cab interior, so it is very pleasant to run now. Just over the last two days, the AC blower started blowing fuses, so I have to get that dilemma resoved. Lack of the blower isn't so much fun, but at least it hasn't been too miserably hot. 99% of my grain samples are less than 1 per cent dockage; they usually run about a half a per cent. All in all, for a 32 year old machine, it ain't bad. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 3:22pm
On a classified ads website called bis-man online, there is what appears to be an excellent 1985 N6. I know nothing about it, except that if I had some cash laying around, I'd be looking into it. Ad says right around 2000 hours, has a Cummins transplant, dual straw spreader. Looks good, just in case someone would be interested. Darrel
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 12:39am
Good machines, just takes more $ to keep up than a L2. For 100 acres, I personally would lean more towards the conventional, but then again, if the N6 is cheaper than a L2, it would probably be worth it.
THe 426 is breathing pretty hard in them, use good oil and keep them cool and think about rolling some bearings in.
They are a 12 row capable machine, but will also do OK with a 6 row.
Look at the cage, bars, and accelerator rolls, as those will be the high dollar items to replace.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
