Replacing brake return springs
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Replacing brake return springs
    Posted: 30 Sep 2016 at 9:05pm
Does the floor pan on a CA have to be removed to change the brake return springs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 4:21am
No, but it will make it a bit easier. I find a bent heavy wire wit vise-grips is the best way to pull them into place.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 10:44am
What Paul said.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 9:55pm
its tight in there to get the old springs out and install the new ones. Not sure you can do it without removing the plate. I drop the spring in and hook the top over the screw head the come up though the front hole with a wire and hook the spring and pull on the wire with a vicegrip or water pump pliers. LOL Bob
Edited by Chalmersbob - 01 Oct 2016 at 9:56pm
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 2:29pm
Thanks for replies.
