KOHLER- K301 ? |
ctbowles 58
Joined: 12 Aug 2016 Location: CLARKSVILLE MO. Points: 129 |
Topic: KOHLER- K301 ?Posted: 30 Sep 2016 at 7:38pm |
The Kohler K301 in my 712H wont start, I have fire to the points but the points wont fire, does that mean the points are bad?
Dgrader
Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Posted: 30 Sep 2016 at 8:27pm |
They might just need cleaned up. Take some fine sandpaper to em.
Ya cain't fix stupid.
ctbowles 58
Posted: 30 Sep 2016 at 9:10pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4061 |
Posted: 30 Sep 2016 at 10:31pm |
is there power to your coil? make sure your battery wire from key or on - off switch has power
ctbowles 58
Posted: 01 Oct 2016 at 3:21pm |
I found trouble,
it was just a corroded wire.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25145 |
Posted: 02 Oct 2016 at 6:11am |
Glad you found it !!
I learned long ago to replace 100% of the wiring on 20-30-40-60 year old machines.... Odds are real good MORE than ONE wire IS corroded.... If you cut the wire, strip and see 'blackish' copper wire not shint clean copper, replace them all. Moisture(water + chemicals) has 'wicked' into the wire. It's only a matter of time before 'funny things' happen or 'it just dies'. To virtually eliminate that, before you put on a connector, slide 2 pieces of heat shrink tubing on the wire, then after you crimp on a connector, solder the wire to the connector. This fills in the wire strands makes it solid. Now slide one HS tube back over the crimp, heat and shrink.let it cool, then pull the 2nd one over and heat it. Done right the 2 layers of HS will make the crimp/insulation area waterproof.It also strengthens the joint ,so less chance vibration will damage the connection. Jay |
