New Manifold Sounds Good!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: New Manifold Sounds Good!
    Posted: 25 May 2010 at 3:46pm
I recently acquired a used WD45 manifold from Andrew Kimbrough - the one on my tractor was pretty well toast - had two large cracks in it. Finished installing the new-to-me manifold this morning - fired up the tractor and all seems well. It's lost several of the symptoms that I thought might be associated with having a cracked manifold on there. I did a check with brake cleaner and had no change in rpm. Great to be able to put a good used manifold to work! Also appreciate the  great job Andrew and his f-i-l did getting it to me.
WC, CA, D14, WD45
Andrew Kimbrough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 3:50pm
Glad its working well for you Dave.  Happy someone could put it to good use!
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 8:19pm
Dave, What are running for muffler on the 45'? Sure hope it's a Nelson, nothing better!!
