Rims are finally done
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Rims are finally done
    Posted: 28 Sep 2016 at 8:31am
Had the rims regalvanized at Roger brothers.
Thanks & God Bless
Dennis
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 8:39am
That looks great and quite a lot of Rims there! I've wondered about having rims re-galvanized vs. painting with aluminum paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 9:19pm
Those look really nice. whats the story with the quantity?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 9:44pm
I wonder if one of those is the good CA rim you bought from me?
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 10:05pm
That looks like the start to a field full of amazing orange treasures.   Just picturing all the options of what that many rims might fit....
Did you need a certain number of rims to make up a batch run? I have wondered about getting a set or two rims done myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 11:23pm
 The more rims you do the cheaper the price.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 11:24pm
 You are correct.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 11:26pm
Are they for sale or own use
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 11:29pm
 Rims are for 3 WD's, 2 WD-45, 1 D-14, 2 D-15's, 1 D-17.
 This is the first batch. More will be going this fall.
Thanks & God Bless
Dennis
 All being used
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 12:26pm
Musta been a lot of tractors on blocks.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 1:05pm
I have 5 on jack stands and Ted has about the same
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 1:10pm
After mounting
Thanks & God Bless
Dennis
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 2:45pm
Nice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 2:58pm
They look even better mounted. Mind sharing how much per rim to have galvanized in a group like that? Did you have to any prep before sending?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 3:28pm
$30.00 per rim. No prep needed unless rims are painted. If painted you must remove the paint before getting them galvanized. They give rims an acid bath before galvanizing. The acid Bath removes all the rust.
Thanks & God Bless
Dennis
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 4:08pm
Thats not too bad, really.  I couldn't have one blasted and painted for that.
AaronSEIA
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 4:25pm
How long does it take them to do a batch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 5:28pm
AaronSEIA
Well you still have to get them blasted just not painted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 6:42pm
 This batch took 3 weeks
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 6:49pm
That is very cool do you know about how long the galvanized rims hold up? I know they all came galvanized or nickel plated I think on the farmall. The farmall h I have was bought new in 50 but as long as I can remember say early 80s it has been just 100 percent rust brown so I don't know how long to expect the galvanized rims would last
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 6:59pm
 The first batch was 16 years ago and still no rust. The CA sits out side 95% of the time.
Edited by DennisA (IL) - 29 Sep 2016 at 7:00pm
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 7:33pm
these are the guys ??  Google search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 7:39pm
there site says a thin flash coating of 1 mill will last 10- 20 years... The heavy 4 mill coating will last 60- 80 years ......... you get thicker coating on larger sheets, thin coating on wire or bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 7:41pm
80 years hoe much to coat the entire tractor. .....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 7:16am
I'd pay $30 a rim any day to have rear rims done. They look good and would last a long time. That's a good deal. I bet it helps when you can get that big of a batch together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 9:41am
Here is a picture of the rim on my CA that was done 16 years ago. Even the power shift rails are rust free and I slide them in and out a lot .
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 11:20am
Thanks for the photo that looks great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 10:36pm
Yea they look good. Are they loaded with calcium.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 11:32pm
Yes they are
Thanks & God Bless
Dennis
