Fiat Dozer Parts
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Topic: Fiat Dozer Parts
    Posted: 27 Sep 2016 at 10:45pm
Our Fiat supply line in Oz - just now.
One of our FA 10 carrier rollers was showing a bit of tooth ache in the bearings and starting to leak oil a bit.  The shell is worn but useable in our situation.
A new roller was $A 325.
The parts book shows the bushes and seal available, so I tried one of our local suppliers.
Bushes were $A16.40, seal $A 34.75 and o-rings $A 4.60.
The shaft polished up OK so I set about ordering the bits.
Available off his shelf.  Delivery by post 1 day.
What I'm pointing out is that there doesn't seem to be a lack of even obscure Fiat parts - from previous references just in your part of the world
Edited by Ian Beale - 28 Sep 2016 at 12:20am
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 7:41am
The theory here is, run it until it breaks scrape it and buy another one. That makes good sense doesn't it? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 5:01pm
Leon
You must have a bigger budget than I have!
That roller is going to do ranch service for a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 5:57pm
Here trying to find things that are AC or A/F is hard as the supply chain seems to keep changing .
 To get parts unless you find a place that has used thing hidden or not sold because no one knows they are around - is next to impossible
Lawrence View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lawrence Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 7:47pm
Is there any market for AC 45 Grader or HD-17 parts. They are both at local a scrap yard waiting to be scrapped. Both look near complete. Not sure if the HD is a 17, forgot to identify it better before I left the scrap yard. It is huge, might even be a HD-20. Let me know and I will go back next week and see if they are still there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 11:07pm
Coke in MN
It would seem that the parts are available but that they're not getting through your supply line.
I should add that this is for Fiat sourced machines sourced from Italy - I doubt it will be much good for AC ones.
