Rotilling with the B
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: Rotilling with the B
    Posted: 25 May 2010 at 8:33am
Sherman made auxiliary trannys that bolted between the torque tube and the factory tranny. Somebody had a picture recently of one on a CA I think. They were made for WC's and lots of other tractors, Ford 8N comes to mind. They are not too common so start looking hard and save your money. I should note that some were step up and some were step down. I have heard of high and low in the same box but don't know about those.
Edited by CTuckerNWIL - 25 May 2010 at 8:36am
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 8:24am
Nice counterweight on the front. If you had one of those Sherman under drives, you might have a good tiller tractor.
You've piqued my interest, what is a Sherman under drive?  I did a google search but could not find anything.  Do you have any pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 8:21am
Originally posted by Charlie175 Charlie175 wrote:
I have only pulled a 10' wagon with it so far, loaded with kids. I also have used the belly sickle to good effect, its nice to not need to look back all the time!
I want to get a 3 point, but want to keep my drawbar. Can I do that?
Yes, mine mounts to the drawbar also.  This setup is very handy as I can still use my drawbar mounted plow and disk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 6:43am
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 6:36am
Does my heart good to hear all the good remarks concerning my favorate.  Don't forget when the B came out in the 30's quite a few used the B as the main tractor on a 100 acre farm because they could not afford anything else.
Good Luck!
Bill Long
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 6:27am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 10:46pm
www.allischalmers.com : Netcraft / Whois
IP address : 67.19.58.12
Country : United States (US)
Region : Texas
City : Houston
Latitude : 29.7523
Longitude : -95.367
See on Google Maps
Results by:IPInfoDB
Script by : PH
m
I usually mow the grass before it gets tall.  I mow one acre with a 5' finish mower and usually mow in second gear at half throttle.  I have run into problems if the grass is too high, or if it is really thick.  In this case, it would be nice to have a little lower 1st gear.
As for the tiller, it's just too much for the B.
Region : Texas
City : Houston
Latitude : 29.7523
Longitude : -95.367
See on Google Maps
Results by:IPInfoDB
Script by : PH
< ="text/">#flag_userjs {text-align:left;color:black;font-size:10px;font-family:Tahoma;position:relative;z-index:1000;position:fixed;right:0px;top:0px;margin:0;padding:0} #flag_userjs a {color:#0040af;text-decoration:none;border:0}#flag_userjs a:hover{text-decoration:underline;border:0} #flag_userjs .details {position:relative;z-index:10500;display:none;position:absolute;width:20em;top:10px;right:0px;padding:2px 4px;background-color:#fafafa;border:1px solid #aaa;} #flag_userjs .helpDetails {z-index:10100;display:none;position:absolute;width:12em;right:0px;padding:2px 4px;background-color:#fafafa;border:1px solid #aaa;} #flag_userjs .help {display:inline;float:right;}
Edited by Dean (West MI) - 24 May 2010 at 10:47pm
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 10:39pm
How did you keep from going too fast?
Sometimes I think 1st is too fast for mowing with my B, though it does has 14.9 x 24's on the back
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 10:26pm
I always wondered if my B could pull a rototiller, so I mounted a 5', 3-point tiller and hit the garden.  Definitely a little big for the B as I had to run it wide open in first gear in order for it to work.  It would probably run a 4' tiller without a problem, but I still recommend using a 5' disk instead.   I also found the B pulls a 5' finish Bush Hog without a problem.  I could spend all day on this little tractor, it's that much fun!
I'm always looking for some new things to pull with the B, please feel free to chime in letting me know what you run/pull with your B.  :)
