D19 to D15 hyd. valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Topic: D19 to D15 hyd. valve
    Posted: 21 Sep 2016 at 8:10pm
I found a D19 parts tractor that has a three lever valve. Could I install that on my series II D15 to give me two way hyd? All my other tractors have two hyd's and I could use the 15 more if it did as well. Are there any other parts I need with the valve? Thanks Tom
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:49pm
Best way would be to use a front mounted hydraulic pump.   Then you could get higher flow. The belly pump is pretty slow flow in the d serries.
