OT: Harvest TEC acid aplicator woes
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Topic: OT: Harvest TEC acid aplicator woes
    Posted: 21 Sep 2016 at 7:18pm
I'm wondering if anyon has experience with harvest tech acid aplicators for large square balers? I am having trouble with pumps getting warm and shutting off. Cool down and they will go again. Ran same acid for 8 years. Harvest tech kinda blames me for not using their acid?
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:02pm
Look for and double look for low voltage at the pumps when they are running. Low voltage about any motor pumps will make them over heat and then the heat increases the resistance and the increased resistance lowers the voltage some more. Poor connections will be hot to the touch for an easy way to find them. Otherwise maybe you are trying to pump something to thick or hard to pump or maybe a hose has a kink or other restriction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:19pm
I have been battling this all summer. Been through system with a fine tooth comb! No hose kinks. Check valves function. All screens are clean as a whistle. Connections are good with Di-electric grease as well. Have not checked voltage to pumps. That is what I'm leaning towards in the pump control box. I hooked water to it today of well water temp. If pumped 400 pounds before the kicked out. Acid which is temp outside and perhaps a bit thicker takes 100-150 oounds to piss them off!
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:52pm
I'm thinking of measuring the voltage right at the pumps with them running with a digital volt meter and then check it against the battery voltage at the battery posts. A difference of much more than one volt would concern me. You could bypass all the switches and run some pretty heavy gauge wire with a pretty good sized fuse right to them and see if they stay running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 9:02pm
I have made a set of jump wires from a new battery. Pumps will run on them. I have yet done a duration test, tomorrow's job. I am not sure if the pump control box limits voltage to pumps or if it's a straight circuit to pumps?
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 11:00pm
what kinda acid and why are you pumping out ona bale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 6:27am
It's proprionic acid with citric acid. Some other brands have other small ingredients. It is applied on hay baled between 15-25% moisture to change ph and aid/prevent heat damage and mold! In MI we go through lots.
