d21 and narrow front
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Topic: d21 and narrow front
    Posted: 19 Sep 2016 at 7:49pm
what is needed and what kinda job would it be to put a narrow front from like a d17 or something under a d21... i know they would be light and very break able ..
i do know that ppl put them under 21s in the 70s for pulling and i heard how they broke them off
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:12pm
Just wondering why you would want one? Not much for practical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:21pm
Even the One Hundred series ones would be sketchy,,,,, if your pulling and come down on it it in a pull, it'd snap off, seen it
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:34pm
mostly to be to have something odd
 would it even be square or would it be gaped in places???
Edited by acd21man - 19 Sep 2016 at 8:36pm
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:02am
Had a D 17 under my D 21 puller. Dustin Swalle in CA has it now and can take some photos. Doyle Bounds in MO. did it originally. Worked and looked sweet!!!
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 11:04am
Pm sent
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:25pm
I thin it would be ugly!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:31pm
X2
Unless it was a big FWA single front wheel LOL That would be interesting.
Edited by CrestonM - 20 Sep 2016 at 12:32pm
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 1:09pm
I know its not AC. But I wonder if a beefed up International narrow front like the ones some auction companies use for loading out equipment would bolt up or could be fabricated to fit the D21? I've seen numerous IH560 loader tractors equipped with the big semi dump trailer extendable cylinders & a long boomed loader. Those things lift heavy tillage equipment onto trailers without grunting. They usually have big wagon tires on those narrow fronts (16.5-16.1?). How would that look on your D21?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 1:41pm
uglier
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 2:25pm
https://youtu.be/x4EJ-Ky_G9E not sure if the link works but here is pictures of onr
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 9:01pm
I second the ugly,good way to ruin a D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 9:03pm
Yep!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 6:30am
Back in the day nearly anyone running well with a D21 puller had a trycycle  front. I've seen some botch jobs and some well done ones over the years. With the casting alone weighing around 1000 pounds, it was an easy way to drop down a weight class.  With everyone going GAGA for 180 & 190 trycycles why do you thing a D21 tricycle is ugly?
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 6:42am
I looked at some of the pullers and they used a small front end, probably for weight and agree it looks ugly. Looks like an elephant perched on a beach ball.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 6:28pm
dang so much hate:( lol
