6080 Differential Filter
NEB-KC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEB-KC Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Differential Filter
    Posted: 19 Sep 2016 at 11:44am
I trust questions that should require no answers can be asked.
My 6080 has two oil filters side by side on the LH side of the tractor where the manual shows the differential filter to be located. The manual appears to show a single filter in that location. The two appear to operate in tandem, at least sharing common oil flows. What is the function of each and how can I tell which is which?
I suppose I could just take off both and obtain replacements, but I would like to have some idea what I am doing.
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 1:29pm
One is a return hydraulic filter.  You probably have a later model 6080.  Both are obtainable from AGCO
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEB-KC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 1:51pm
Thanks. That makes sense. My 6080 is a 1983 model.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 4:18pm
The filter part numbers are 70253952 and 70270958.
This page was generated in 0.758 seconds.
