Farm stock pull results
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Topic: Farm stock pull results
    Posted: 18 Sep 2016 at 7:26pm
6500 the D19 hitch pulled out of the yoke up front and ended up in 4th place.
7500 chained the front part of the hitch to keep it from coming out and the 19 got 2nd to a 450 that it usually beats.
8500 The fencerow 190 was pulling in 2nd high and when the weight box started putting the load on it was like the power director just gave out and popped into neutral.
9500 Weighted up the fence row 190 and pulled in 2nd low and it held better but was surging a little bit felt like the power director would start slipping and then grab. It did that about 4 times down the track and ended up with a second place.
11,000 The other xt held its own and ran out of power in 2nd low taking 2nd to a JD 4620
12,000 weighted the xt up to 11700 pulled 1st high and took the win loosing traction but put a few feet on an Oliver 1850 that got 2nd and put about 20 foot on a turned up D21 that got 3rd. There was also another d21 in that class but was back with the other. All in all a fairly decent day all the classes were payout classes and I actually came out ahead by 20 bucks at the end of the day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 8:00pm
Sounds like a great day of action, you,'ll find the weak points when hooked to the sled!
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 9:12pm
Some Lucas trans. treatment might help the slippage problem. Who knows? Worth a try I guess.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 3:33am
Nothing ever breaks down in the barn!
