D17 series IV dies after reaching operating temper
Too Tall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Topic: D17 series IV dies after reaching operating temper
    Posted: 18 Sep 2016 at 6:36pm
My D17 series IV late model starts fine and runs for 10 minutes then dies, and won't restart until it cools all the way down. It has good spark and gets gas. It is a weird deal. If I am working it will start to sputter and lose power before shutting down.
When I let it sit there and idle it will just plain shut off in 10 -15 minutes. It won't even pop until I let it set for a half hour and then it starts great, and then does the same thing every tine Any ideas? Thanks
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 7:02pm
Sounds like a bad coil or condenser. Once it dies check fire at coil, if you still have fire then check fuel flow for at least a minute out of carb bowl, but I would guess ignition. Leon
Bob (IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (IN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 7:06pm
Check to see if fuel cap is vented
great-grandpa's wc with picker, 20/35, speed patrol, uc, m crawler, 620, 653 dozer d21 d17 d19
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 7:22pm
I would start with the coil and condensor first as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 9:45pm
Thanks. Tonight it would not start at all, so I pulled a plug and it had spark but it seemed like it would skip and was a little weak. I thought about a carb kit but after reading what you guys wrote I will start with a new coil, condenser , points and plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 10:43am
Installed all the parts I mentioned above and it works fine. Thanks for the advice
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 10:59am
Too Tall,  Great to hear.
As I was reading this thread I was thinking "back in the day" that is exactly what I would do.  Might be overkill but all new parts would get the engine running well for quite a long time.
Good Luck!
Bill Long
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 11:57am
It's nice to hear feedback. When someone has a problem I like to know what actually fixed it. Everyone learns that way.
This page was generated in 0.336 seconds.
