WD 4th Gear
WDDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDDave Quote  Post ReplyReply Direct Link To This Post Topic: WD 4th Gear
    Posted: 17 Sep 2016 at 3:44pm
   What would cause the shifter only in 4th gear on my WD (straight shifter) to not go back as far as the other gears?
   4th gear does work but it feels like it is barely engaged I haven't driven it far enough to know if it will stay in or pop out of gear but seems to stay in just around the yard.
Could this be a bent shift fork?
    Is it a big deal to remove the shift tower or will 100 pieces fall out of place when I do so?
WD ,wide front, with loader
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 4:13pm
Don't go looking for trouble...It's probably normal(at least that's been my 60 year's +experience with these girls!
regards,
Ken McGregor
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 5:28pm
4th gear has a very short throw, it's normal
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 6:39pm
WDDAVE...My 1950 WD feels exactly like you are describing...I think they are all that way?? I would not try to change a thing.
Edited by allischalmerguy - 17 Sep 2016 at 6:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 7:03pm
Sounds like there's nothing to worry about after all.
Didn't know there were others that were the same way.
Thanks guys for your input!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 8:03pm
I've got three WD's and they are all that way and all work just fine!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 10:12pm
4th gear in all of mine is shallow. "Don't worry bout it"
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 9:05pm
4th gear only couples to another gear while all the others slide the width of the gear to engage.   MACK
