Rim clamps, what goes where?
Jonny B 1938 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Topic: Rim clamps, what goes where?
    Posted: 17 Sep 2016 at 3:27pm
OK I have two different rims I noticed after taking the tires off, one is a bevel and one a four bump. Now I see after looking in my bucket of parts I have four different rim clamps, so are the bevel clamps different for one wheel or another or do I use two of one type and two of another on one wheel? The C laying behind the barn has four bump rims but two different clamps on each wheel, my B has different clamps all together but kind of the same arrangement of two different clamps on each wheel. Not sure what is what and the service manual skips right over the rim installation instructions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 3:33pm
you should have two clamps that use standard 5/8 inh bolts , and two that have "cam bolts" that you can twist and they will cam- over and tighten up the slack... The two standards go next to each other ( 12 and 3 oclock) and the two cams go next to each other  ( 6 and 9 oclock) example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 3:35pm
I have seen small variations in clamps built 10 years apart, but the setup above is always the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 3:40pm
Ok the C has them opposed from each other so those are mounted wrong too. At least I do not need new clamps, just rims, what a mess. I am going to have insane money in this thing by the time I am done, four new tires and I already welded new front rims on the riveted centers. Its like the Million Dollar Tractor, I have the technology but not the funds LOL.
Edited by Jonny B 1938 - 17 Sep 2016 at 3:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 3:57pm
So I have one with a 1/2" hole and all the others are 3/4. Three have a recess built in all the others are flat on the face, so are they all supposed to look the same outside? Or two flat and two recessed on each wheel, I obviously have a mish mosh of parts on my hands?
Edited by Jonny B 1938 - 17 Sep 2016 at 4:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 5:25pm
UH OH I set my rear rim centers side by side, they are completely different too. I am very close to parting this thing out and buying another tractor.
This page was generated in 0.157 seconds.
