All-Crops and Soybeans Question
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: All-Crops and Soybeans Question
    Posted: 14 Sep 2016 at 5:31pm
Ok, so most Okies don't grow beans, but a lot of you guys do. From what I can tell, when you run beans, you are always adjusting the header to hug the ground. When you use an All-Crop with a hand lift, do you just keep adjusting it all the time? Or do you just set it in a "kinda low" spot and call it good?
Edited by CrestonM - 14 Sep 2016 at 5:31pm
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:48pm
If your ground is as hilly as ours in piedmont N C you will need to keep a hand on that lever most of the time.
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:58pm
Why didn't AC make some sorta caster wheels for the pick up?
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:44pm
If your smart you hire someone with a flex head. Money well spent. Someone on here posted pics of a field combined by a all crop I bet it left 5+ by/ acre in the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:57pm
That's what I'm saying! Have caster wheels an inch or two in front of the sickle guards, and have some sort of quick disconnect for the header. That would work, I'd think.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:58pm
we always had our hand on that lever, and could shave the stems off right at the ground. trick is...to have a level field when planting, unless you plant on top of ridges!  disk furrows stay all year.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:07am
In some areas they roll the field after they plant beans to push rocks down and smooth the surface out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 10:55am
Dad mounted a seat backwards on the W C and uncle rode it and kept a hand on that lever.When we finished a field of wheat there would not be a head left.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 11:09am
i ran my 90 in soys I was able to clip just as short as our 35 foot deere hydra flex and the 90 made a cleaner sample
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 12:23pm
Set mine as low as I can go without bunching up and pushing dirt. We roll the fields so it's level, don't have to play with the lever much. Drop it and go. It's alot of fun!
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 2:11pm
odds are if your running an allcrop you also dont have a perfectly flat seedbed. smaller equipment is hard to level a field with.     if you have rocks forget getting the low pods not worth destroying the cylinder for a few bushel.
i see about one rock per year here so i didnt worry much when i used mine. i did fill the header with dirt a couple times not paying attention.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 2:28pm
You mean the rock trap won't catch them all?? LOL
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 4:10pm
You set it so it doesn't run in the dirt and leave a whole lot of beans for the birds.
