180 Allis temp. sending unit
180shane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Topic: 180 Allis temp. sending unit
    Posted: 13 Sep 2016 at 8:54am
Got a 180 that doesn't show the temp. Figuring on replacing the sending unit because I thought that would be the easiest thing to start with. Well I stripped the threads trying to get it off and even used vise grips. That thing must be welded on. Any ideas on how to get it off or do I need to replace the thermostat housing? TIA
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 9:05am
heat it with a torch, its already junk and may have sealer on the threads holding it tight
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 9:40am
Just be sure to drain the coolant before you try to torch it or it won't get hot enough to be very effective.
