Allis chalmers disc
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers disc
    Posted: 13 Sep 2016 at 5:36am
I found a disc for sale that is 25 feet wide. Suppose to be in working condition but I can see its  missing a blade and I think it needs a few more blades too.
Im guessing my Allis 7040 wont pull a 25 foot disc? I would have to buy duals im sure.
Im at stock horsepower I believe with loaded tires.
Heres a link to the disc
http://www.kijiji.ca/v-cars-other/norfolk-county/25-foot-allis-chalmer-disc/1197140058
Tell me what you think, if I should run from it or maybe it just needs some work. It also doesn't have scrapers so that might be a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 5:37am
If you highlight the link and right click , there is an option to go to the link.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 5:40am
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 6:06am
That looks really nice for $3000, even needing a little TLC. I would think your 7040 would pull it but it depends on the soil type and if it is hilly. My opinion is that would be the largest disk to pull with a 140 hp tractor "here" in relatively flat sandy loam soil. I pulled a 30' disk with a White 2-150 years ago and it had plenty of power for the disk at 150 hp.
Part time farming with a 1980 7060 and 1984 F3 hydro.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 6:11am
it is missing a few disks and scrapers, they are relitivly cheap if just a few are needed, can use chain for scrapers like I explained earlier in a post. the blades also look quite wore down. but will still work for awhile. AC disks pull easier than most. but i'm sure you will need duals. 7040 should pull it o-k.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:12am
I might go take a look at it. I'm just afraid of I buy it I won't be able to pull it. My ground is Loam. Not really clay or sand. I am using a 10 foot bushog disc that doesn't cut at all. I used to pull the 10 foot with a Massey 165 or a 990 D
david Brown. I don't want to kill my tractor trying to pull it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:17am
That disc has adjustable gang angles, so you can lighten the load a bit at the lowest setting. Four really good matched rear tires on your 7040 are a MUST if you're going to try to pull that disc.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:29am
I have a 26ft just like that. I pull it with a 7060 and 7080. Traction is the issue I have plenty of power. I've never had it behind my 7040 but in a pinch I wouldn't be afraid of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:32am
Dr. Allis I might pass this one because I have worn firestone spade grip rice tires on it. I also don't have duals yet. I might look for a 18-22 foot disc. I really want one that will actually cut , not a angle frame disc
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:33am
I would also say you'll either want fluid filled rear tires or weights also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:35am
I do have fluid in my tires. I just think I will run out of traction
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:52am
*off color - may not be suitable for sensitive readers*
When I was a kid, we used to pull a 24' white disk with a Deere 4520 with fluid and duals. Only 130 HP, but about 500 lbs heavier than you maybe. Had 18.4 tires. Pulled it ok I was told. I pulled it once with a 4440, can't remember if it had fluid then. It pulled it fine, but if you hit a little wet or sticky spot, you were raising the disk.
A couple years later they bought an old Deere 4wd 7020. I pulled it a lot with that and never had any traction issues.
I don't know how the white disk would pull compared to the Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:59am
It's a tough choice. I don't want to pass it up but it would be the max the tractor would pull. I like the case 490 discs but they are 8000 plus dollars
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 8:03am
You could probably resell if it didn't work well for you.
If you're disking now though with a 10' disk, you must not be doing that many acres and maybe a 20' would be better. Even then you'll probably want duals.
Edited by Allis dave - 13 Sep 2016 at 8:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 8:11am
I did 40 acres this year. 70 next year and hopefully keep expanding. So no not a lot of acreage so a 20 foot will work Just fine.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 1:41pm
Unless you have really flat fields and light soil I think you are going to have a hell of a time pulling that disk with a 7040.  We used to pull a 19' Deere 220 disk with a 4440 (about the same HP as a 7040) with duals and fluid in the inside tires and on occasion we had traction problems in some conditions.
Our neighbors used to have a 24' AC disk identical to the one you are looking at and they always pulled it with a Deere 8430 articulated 4x4.
Edited by VAfarmboy - 13 Sep 2016 at 1:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 2:05pm
well a 25 ft disk is gonna pull a lot different than your 10 ft disk!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 4:28pm
We have a Center Fold 3500 I think it is, with near new blades, narrower than that one, and our 7030 in good shape will not pull it in flat silty loam, unless you are in a low gear, and then you run out of traction without duals.  Our 7060 weighted up with duals plays with the same disc, so as others have said, I think you are borderline on being able to do it with the setup you have.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 4:35pm
2500, not 3500.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 5:35am
I am going to pass on it. I dont think my tractor will pull it. I think 20-22 feet is enough for this tractor. I will keep looking around maybe another one will come up for sale.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 2:24pm
If a 7040 wouldn't pull that disc, l would get rid of the 7040 before l got rid of the disc.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 2:32pm
I think you're smart for passing.
You said you had worn out tires. You said you would need to buy duals. So you're looking at, what, $4000 in tires to give your tractor a shot with a 25' disc that needs work? Go 22', and drive a little faster when you can and not work the snot out of it all day long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 4:48pm
Yeah thats my exact thoughts. I dont have enough experience with my soil also to be sure how it will pull. These tires will still last me a couple seasons but I doubt they would pull a 25 foot disc.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:42pm
Since it is going to need repairs why no take two disc off each gang.You would only need to shorten the axles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:47pm
If I did that would I just have to take the axle shaft to the machine shop to get new threads after I cut it down?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:27pm
You wouldn't have to shorten the axles at all. Just use the center of a wore blade as a spacer. You'll be at the same length.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 3:16am
Yup or build it out with anything like stacking washers or pipe. We had an 12 foot I think ac disc set when I was a kid. It didn't fold and was almost too wide to transport it would be over both the yellow and white lines at the same time. Anyway that disc had sealed bearings and we would have to replace two every summer dishing 150 acres two passes so 300 actually acres I guess you could say but the second pass pulls alot easier smoothing it out. Anyway the bearings where 100 each back in the 80s that is what would scare me with a used disc I'd someone abused it and ran it with bad bearings you could have one heck of a repair bill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 3:29am
wow.....
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 5:17am
Nick, I'm in Ontario and will likely have a set of 38" T rail snap on dual rims and hardware for sale. Will know for sure after Saturday.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:03am
Too bad your not closer, I have a 18 foot Krause disc for sale that would be great for your 7040. I has 19 inch blades and in good shape. Probably going to take it to Mowery auction today. With duals, unless you really go deep, your 7040 should pull it. Friend of mine had a 21 foot 490 and it played with it. Good luck. If you look around you can find a nice 490 around $3000 also.
