My 1st Allis Model C (Updated 12-4-16)
Bensjamming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Topic: My 1st Allis Model C (Updated 12-4-16)
    Posted: 12 Sep 2016 at 4:58pm
Well I received a gift of a 1945 AC model C. It has the pto shafts on the rear as well as a hydraulic lift system that looks original on it and a shafts that a pulley would go on under the seat to drive other implements. Now this is the 1st allis chalmers I have owned and my 3rd ever tractor. Prior ones being a 60s model international 300 which is gone now, and now have a Ford 881 Powermaster and this little gem. So far I just l9ve this little thing.
Upon getting it I was told he thought the head gasket was bad since it overheats after light use and he just put on a new water pump and thermostat not that long ago and it didn't solve the problem. After getting it home lastnight I took a little ride for like 30 minutes and at the end the new temp gauge read in the high green area then rose slightly into the red after shutting it down. I could hear the coolant boiling a little too.
After it cooled down I check the radiator and the coolant looks kinda nasty so I plan on flushing and replacing that as well as a oil change and change the fluids in the differential and what not
I also pulled the valve cover off and there is so.easy white slime inside the cover from what looks like moisture so Amy be the head gasket is blown pushing coolant the into the oil a little bit?
Any help or advice would be appreciated as I want to get it in great running order then fix it up cosmetically and just use it around our property for dragging trees and pulling firewood back to camp. Maybe get a blade or something for snow removal at home if it won't break the bank.
Will get a few pics of it up here shortly.
Edited by Bensjamming - 04 Dec 2016 at 12:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 5:01pm
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 5:23pm
I don't suppose you have tried cleaning the radiator fins out?  When it running hot is the air coming off the fan equally hot too?
If it ever got used like any of our numerous tractors have, and it's rare that one hasn't, there's a good chance part of the overheating problem could be related to the radiator not being able to breath.
Also you first picture needs to be a 'Gettin' ready to Cruse da hood country style." Meme.   LOL
(My daughter loves tractor rides too!) Wink
Edited by Tcmtech - 12 Sep 2016 at 5:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 5:50pm
Yeah she is already asking if it can be hers when she is older. Lol
The fins are clean. I can see right through them. Didn't check the air temp off fan if both upper and lower hoses were hot but could see the coolant swirling around in there when I started it cold for a minute this morning. At work now so cant try anything till at least 1130 tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 6:25pm
What is the easiest way to be able to hook up a small rear blade onto this tractor for pulling light snow down a driveway? Anyone have some ideas or plans on how to make a simple 3 pt setup out of the hydraulic lift that's on these machines already? I'm a Welder by trade and have the equipment to fab up pretty much whatever I need.
Thanks in advance, Ben
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:10pm
That is one CLEAN C.  Looks like it has been restored.
How lucky!  A gift.
For a snow plow you may want to look for a myers blade.  We put a lot of them on C's and they worked very well.  Are the tires loaded?  That will make pushing snow or pulling anything a lot better.
The B-C, CA's were rather "cold" running tractors.  You are changing the fluids and that should help.  Be sure to flush the cooling system.  Only other thing - and I hope not -could be a plugged block.
Let us know how it goes.  Neat Tractor.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:12pm
Never has been restored. Was just told it has never spent a night outside in the last 45 years and that was the only stipulation to me getting it for free, is it has to be stored indoors.
Im also getting a restored massey harris 33 from as well as soon as I go pick it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:13pm
Ben, welcome to the Forum. There are several vendors on this site that sell 3 point kits for the B and C, but if  someone on here will send you some pictures you could fabricate your own. The overheating could be caused by water passages in the engine and /or the radiator being blocked by years of crud buildup which can be a problem to remove. The B's and C's usually run a bit on the cool side unless you have a problem. That is a nice looking C with good tires on it. And I see you already have a driver for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:13pm
How lucky!  A gift.
Good Luck!
Bill Long
With the Meyers plow do you mount it the bar underneath for the implements? And how do you raise and lower it? I was thinking just a rear scraper blade myself but if that's going to work better and be easier I'll go that route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:20pm
Yep. My daughter's the same way, Almost 8 now.  Don't want the old Farmall A fixed up for her. She wants Grandpas old Case 1150 dozer so she can push stuff and blow smoke with it.  LOL
Then unfortunately you're probably right. it isn't just a radiator problem unless you have a lot of mineral deposit crust built up that's either plugging or insulating many of the inner passages of the core.  That old Case dozer was like that when we got it.  Good circulation but very little heat transfer and ended up be a near $1000 recore job to fix it. Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:31pm
The Myers blade for the C pushed in front of the front wheels.  It got it's lift from a cable hooked to the lift arm with a series of pulleys that lifted the blade.  Be sure you get a blade not much wider that the rear tires, otherwise you would have too much blade for the tractor.
There was a B in one of the older posts with a Myers plow on it.  Different tractor but mounted almost the same.
Perhaps someone has pictures or diagrams.
You might want to try the Myers web site.  Perhaps they would have a parts book.  If you were really lucky they may have some brackets in New Old Stock.
Good Luck!
Bill Long
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:38pm
It's been repainted. It has incorrect decals and orange rear rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:52pm
 1. After getting it home lastnight I took a little ride for like 30 minutes and at the end the new temp gauge read in the high green area then rose slightly into the red after shutting it down. I could hear the coolant boiling a little too.
2.After it cooled down I check the radiator and the coolant looks kinda nasty so I plan on flushing and replacing that as well as a oil change and change the fluids in the differential and what not
3.I also pulled the valve cover off and there is so.easy white slime inside the cover from what looks like moisture so Amy be the head gasket is blown pushing coolant the into the oil a little bit?
1. High green is OK, but these engines tend to run too cool not to the warm side. If the radiator shutters are all the way open it should probably stay closer to the low side of the green.  ANY engine will show higher temp after you shut it down, that's not a problem.
2. Flushing is probably a good idea.
3. With the valve cover off, look for core plugs in the top of the head. If they leak a little bit, it can cause the milk shake in the oil. They MAY look OK but they rust from the bottom side and will eventually leak, letting coolant drain down into the oil pan. NOT a thing to let happen because antifreeze in the oil will destroy your bottom end bearings in a short time.
 This is a cheap and easy thing to fix. Core plugs, or Frost plugs can be bought for a couple dollars and once the coolant is drained down below the head level, you can drive a screw driver thru the old ones and pop them out. Clean the casting with sandpaper and wipe a SMALL bit of sealant around the hole and tap a new plug in.
 The tractor may have never been "RESTORED" but it HAS been repainted. There never was a "C" decal on a C and the rear rims were never painted Orange. They were galvanized. That being said, I wish somebody would give me a couple tractors to store inside Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 8:20pm
Thanks! I hear guys saying they were painted, which starts a whole other argument Lol
I think Bill Long said it depended on the supplier, so maybe everyone is partially right.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 8:57pm
What you have here is what is known as a "Short Arm C" referring to the short steering arms. They are very early Cs. The short arms were replaced by long arms at C#18163 that would be in late 1942. Beginning number to be a 43 is C#18782
If in fact,as you say,it is a 1945 C the tractor number should fall between C30695 and C36377
I'm surprised no one has pointed this out before me.
If your numbers match the numbers for a 1945 the transmission was probably changed. Probably a Restored Tractor.
Nice C regardless of year it is. The forward facing drawbar under the tractor is used with Tractor mounted B/C plows. The plow debth control lever is missing. I have that lever if you ever need it to mount a plow.
The two lift levers in the rear are also part of the C Left right two Plow setup.
Edited by Ken in Texas - 12 Sep 2016 at 9:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 9:17pm
Here is a picture of a left right 2 plow set up on a B for reference.
The ones on the B are independently operated up and down by hydraulics.
   The two hand levers on the C here indicate the plows were independently raised and lowered by hand.
Look close at the B and you can see the plow debth control lever to the right of the steering wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 9:33pm
There is a lever on both the left and right sides similar to yours. The right side raises and lowers the bracket in front of the rear wheels the plow woulster attach too and the other one on the left moves an arm with 2 steel rods or bars that are mounted the end of it.
If I recall the serial number was right in the middle of the 1945 serial range. Is there anywhere else I can look for a matching number?
Also any idea what the steel rods are on the ends of the rock shafts I believe it's called. The hydraulic lift bar?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 9:36pm
In this image you can see the 2 handles that are either side for the lift. If you look right behind the slow moving vehicle sign the rods I'm asking about are standing up against the sign. The other side has 2 of them as well....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 9:49pm
Man alive. This C has real C fenders what aren't rusted half away up.
Those goofy aftermarket headlamps got to go.
That funky excuse for a drawbar extension needs to go too. A real AC B/C swinging drawbar would look perfect back there.
Doing it right makes it worth doing on a FREE tractor
Edited by Ken in Texas - 13 Sep 2016 at 7:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 10:02pm
Ben
sorry me can't see a plow debth control lever on your C. My plow debth control lever bolts to the footrest on the brake side.
That rockshaft "tool Bar" with the two levers were also used with C two row cultivators.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 10:09pm
Ask your guy that gave you the C if it once had plows or a set of cultivators. Why they leave important attaching parts for implements stay on the tractor when nobody without the rest of the implements can use them for squat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 10:22pm
One more Question and I'm going to bed. Are there any hydraulic cylinders up under the seat I cant see and is there a two way valve in the hydraulic line system anywhere?.
We can hash this mess out later.
one more thing. Is there any kind of bracket bolted with 2 bolts to the top of the final drive housings between the tire and the fender?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 10:30pm
Is that a 450r behind it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 10:32pm
There is a small high psi cylinder under the seat on the right side of the tractor. I'll be off of work in 30 min and will check it out then n put up some more pics.
Thanks for the help it is really appreciated.
Close, its the oldest kids 400ex.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 10:49pm
Oh you know I was going to say that first but I thought I would be date in myself lol
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 11:01pm
Ken
Only the B uses that front plow adjuster lever. The c uses the levers on the rear rock shaft to adjust depth. A manual lift for the C is very similar to the manual lift on a B and mounts on the right side of the tractor. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 11:18pm
I finally figured it out CB after digging out my B/C tractor mounted plow manual.
What he has there and won't use could make somebody with a C and a plow with no mounting hardware a very happy camper.
Having never set up a plow on a C I was just guessing.
What are the 4 rods attached to the rock shaft he is taking about? One pair is up the other hangs down.
I guess the big ? is what year is it? and What happened to the plow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 12:43am
Here are some pictures of everything along with a shirt video.
1st pic is the left side and the 2nd and 3rd are of the right that raises and lowers the bracket in front of the rear wheels.
PTO and Hydraulic pump and cylinder
White slime in valve cover and top of head with rockers
Carb / Alternator
Sanded the serial number to see it better
1 other view of the lower bracket where plow would attach
Video will come soon. Still uploading...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 1:07am
Also after sanding the paint off the serial number it dates to a 1942. The 2nd year the C was made. My mistake on it being a 45.
Serial number is C15331
