allis sickle bar application ??
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Topic: allis sickle bar application ??
    Posted: 10 Sep 2016 at 2:17pm
have a sicklebar that I cannot cross to an  ID...it is either harvestor or combine...about 25 sections.....Part number on the bar is 5354961-   Any help would be appreciated..Mark
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2016 at 2:56pm
If is AC, and the # is on the cast drive head, (535496) it could  be for an AC combine. I think that would be the only place there would be a # on sickle bar. I'm not sure, but I think the 60 had 22 sections and the 66 had 25 sections. Some one will know...Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:11am
Can anyone cross reference...thanks, Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 1:26pm
the # I gave above is the # for the head only of the complete sickle assy.  all the other parts of the sickle components (sections, rivets, bar) have individuals also.  Those #'s may be used individually or on other assy products not related to this subject.
 Sickle Assembly #'s could be (70)500786 for a complete sickle for a 60 series or (70)513836 assy for a 66 series combine.  Your questions are a little vague.  What is it you are wanting to do...HTH
Dale
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 11:39am
Thanks Dale...want to use it on a 72...possible a very late serial #  and probably for the head only....can backyard engineer it to fit...If someone has a late 72..could you check the sickle bar head...Thanks. Mark
