Onan CCKB starter
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Topic: Onan CCKB starter
    Posted: 06 Sep 2016 at 5:05pm
We recently bought a new started from B&B formu 620 and noticed it only has 9 rotor teeth while the original has 10. My dad says he was always told that you can't use 9 teeth ones one them, but we would like clarification on this subject. I did talk to Steve and he said they work but my dad wants other people's insight.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 8:57pm
I'm not sure HOW you can get a 9 tooth gear to PROPERLY mesh with a ring gear that was DESIGNED for a 10 tooth starter gear. There's just NO way it will work PROPERLY. I'd have to dig up a Machinest handbook or 'Gear cutting 101' to get specifics, but a 9 toother will not properly mesh. I 'suppose' you 'could' add washers to mount the starter away from the ring gear and some of the 'face' of the teeth will just touch the ring gear but that's NOT how it was designed.
If some gear guru can explain, I'm more than willing to listen.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 9:17pm
We looked up online and it says do not use the starter to replace the cast-iron head   10 teeth
This page was generated in 1.484 seconds.
