d16 dozer will a 855 Cummins swap work?
jeffyexley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffyexley Quote  Post ReplyReply Direct Link To This Post Topic: d16 dozer will a 855 Cummins swap work?
    Posted: 06 Sep 2016 at 1:13pm
I want information on swapping a 855 Cummins with the factory Allis Chalmers motor on a d 16 dozer.thamk you any information pertaining to engine conversion in similar machine will be appreciated.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:57pm
It's been done- there's a thread on the Heavy Equipment Forums about it...
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 9:29pm
Same idea, different animals.  There is the start of a JD engine swap into a  HD21 over at Van Natta Dozers site.  They aimed to start with a Cummins and detail the traps found which caused the selection of the JD - which should apply to a 16 too.  Last time I looked the project had stalled before completion.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 3:10am
From memory, the the repower to Cummins on H.E.F was a complete success, and the owner never looked back. 855 cummins would be the most logical choice if you want away from 844 Allis
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 3:39am
yes I think he calls himself 'HD16B' is on HEF. 855 conversion and tractor goes very well. He also converted the undercarriage to D7G chains rollers and segments.
From memory the headaches involve a adapter plate for flywheel housing to torque converter housing.
but what he did is all documented on HEF.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 4:14am
IIRC  There were some FD 30s that had Cummins instead of Fiat engines  so that might have helped a swap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffyexley Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 2:36pm
Thanks to all of you. In case it's of interest the situation is a hd16 with a broken crank and hasn't run in 10 year so or so is nearby and I have an old c above with a very solid 855 that I'd like to see put to use. The owner of the dozer don't think it's worth the trouble but the transmission has low hours on o.h. and the undercarriage is in very reasonable condition. I would certainly appreciate any voices of experience in aid to my decision. Thanks again for your time.   Jeff. Ne south Dakota.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffyexley Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 2:40pm
The same fellow also has a blade with water in the oil sat several years. I think it's from the 80s has a nice cab and a snow plow attatchment. I wonder what that would take to see operating. I'm sure the crank will be rusted ect. So I call it a motor swithch. Seems like the
hd16b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hd16b Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 2:58pm
It's td25c on the hef forum.I did know where a complete machine was at 2 years ago. Give me a call at 2529162927
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 4:56pm
Seen one HD16 with a 8V-71 in it out in western MN - nice conversion and they said power was no problem .
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 11:40am
There is a HD11 with a lot of picture on here with a V6 71. It is a Ag tractor named Power no Shift maybe the name of the post even.
Andrew_D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew_D Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 5:43pm
http://www.heavyequipmentforums.com/showthread.php?11819-16b-engine-repower
Andrew
Edited by Andrew_D - 08 Sep 2016 at 5:44pm
HD11B (S/N: 3880) ~1957
This page was generated in 0.488 seconds.
