AC CA tractor rear wheel bolt pattern
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Topic: AC CA tractor rear wheel bolt pattern
    Posted: 06 Sep 2016 at 6:34am
I know the rear wheels on the Allis CA have 6 lugs but what is the bolt pattern? Will 6 3/4 in 6 lug fit?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:40am
Same as a Farmall A or a D 10 Allis. The stamped steel wheel centers from both will bolt up on a CA.   I have Farmall steel whells on my CA puller.
Edited by Ken in Texas - 06 Sep 2016 at 6:44am
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 7:06am
I found some wheels that had 6 3/4 in pattern and was wondering if they would fit. Thanks, Dave
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 11:16am
I measure 6 1/2" thru center. Tim
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 4:03pm
I found some wheels with 6 3/4 bolt pattern and was afraid they were not correct. Thanks for the post. Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:09pm
farmall centers, like a 140, cub or A will fit...
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 7:34pm
Cub won't fit they're 5 lug same pattern as a lot of garden tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 11:40pm
I think you can add Farmall B wheels and drop the Cub. Farmall rear wheel weights work on D10s with stamped steel wheels. Those weights on my Ca are Farmall
Edited by Ken in Texas - 09 Sep 2016 at 3:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 7:50am
Originally posted by Ken in Texas Ken in Texas wrote:
I think you can add Farmall C wheels and drop the Cub. Farmall rear wheel weights work on D10s with stamped steel wheels. Those weights on my Ca are Farmall
Farmall C has a totally different wheel think  its  a 36  inch rim with cast iron centers.Would definitely make a CA high clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 8:57am
6 bolt GMC truck rims fit.........
..kinda makes for a 'low rider' though...
Jay
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 6:41am
Can't find my information on the Pertronix Electronic ignition for my B Tractor. All I remember is Steve. Anyone know the contact info? thx. davh
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 12:48pm
davh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davh Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 4:39pm
Thanks, davh
