Tire/wheel help
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Tire/wheel help
    Posted: 03 Sep 2016 at 6:26pm
I want to put these Carlisle tires on my B with woods mower.  Shown here on the Miller Tire site: http://www.millertire.com/products/tractor-tires-rear/11-2-24_-10-24/11-2-24-carlisle-turf-pro-6-ply/
What width rim do I need?  I'm guessing 10 inch?  Thanks.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
BigMo(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigMo(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 7:18pm
10" should do the trick.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 7:07am
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 10:59am
Hub--Look around you might be able to find that tire for less money than that. It says tubeless, if you use your old rims you will probably need to put tubes in them. Our B has 11.2X24 tractor rears on it and look good on there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 2:23pm
The tires on the tractor now are 11.2x24.  Is that the old size or new?  Does that indicate the size of the rim?  If so, what is it?  Sorry about the questions.  I just can't get the old and new sizes straight.  HD6GTom, could you post a pic of your B?  Thanks.
Steve
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 2:33pm
Okay,
I figured it out.  11.2 is a modern size and it should be a 10 inch rim.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 2:40pm
There is no "old and new" to keep straight. 11.2 is a current size. You have 11.2's on it now and you want to put a different set of 11.2's on it. If an 11.2 ag tire will fit, an 11.2 turf tire will fit the same. If you have 8 inch rims, run a couple pounds less air pressure to keep the tire from getting too rounded.
 You may want to run tubes in them also.
http://www.petestirestore.com/112-24-Carlisle-Turf-Pro-Tractor-Tire-6-Ply-TL_p_5857.html
Edited by CTuckerNWIL - 04 Sep 2016 at 2:43pm
This page was generated in 0.230 seconds.
