b allis final drive reasembly
wkiheri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkiheri Quote  Post ReplyReply Direct Link To This Post Topic: b allis final drive reasembly
    Posted: 02 Sep 2016 at 9:23pm
can you use silicone between the final drive and the differential on a b allis there wasn,t any gasket just a shim between the  differential carrier bearing housing and the case also between final drive and the bearing housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkiheri Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 9:25pm
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 6:01am
It isn't necessary if you replace the inner axle seal.  It should be dry between the final drive assembly and tranny.  So silicone in there would just make it more difficult to disassemble next time.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkiheri Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 9:22pm
thanks for the info I got it put together this afternoon.
