Plow shares and moldboards for B & C two way plows |
AC1945WC
Joined: 04 Jun 2011 Location: Denton Maryland Points: 68 |
Topic: Plow shares and moldboards for B & C two way plowsPosted: 02 Sep 2016 at 7:52pm |
Now I am in search of some parts for my B & C two way plow. I need a left and right moldboard and the left and right shares. The shares have a hook on the bottom for the draw rod to tighten up and use a bolt as well to secure the share to the frog. Any help in finding these parts is greatly appreciated.
AC1945WC
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 02 Sep 2016 at 7:58pm |
I would not hesitate to contact Wertz Power Equipment, Glen Rock, PA They were originally Wertz Garage, an Allis Chalmers Dealer since 1937. While they now sell Massey Ferguson equipment they are an AGCO dealer and may well have or can obtain plow shares and other plow equipment you need.
In fact one of the son's of the Owner, David Dickmyer, has a two way plow mounted on a 1941 C. I was pleased to drive it at plow day. I do not have their contact information but you can Google It Good Luck! Bill Long
AJ
Posted: 02 Sep 2016 at 8:28pm |
Good luck. I have an NOS left hand share. That wasn't easy to find.
Can't fix stupid
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 02 Sep 2016 at 9:26pm |
Knowing the plow frame and the tractor does not identify the bottom and the plow parts. I have a long treatise on the topic with links to parts book AC Plows Parts 101 over on the Knowledge Forum. You need to find a plow bottom component part number, like the frog, moldboard, or plow share. Several bottoms used the hook to hold the share in place. The details are in the bottoms parts book referenced in AC Plows Parts 101. Allis tended to offer at least a half a dozen shares for any bottom side and width, doubled for two sizes of width, doubled for left and right.
A rough guess would be a 25 or 125 bottom, but that's a wild guess. Gerald J. |
ICTRCTR
Joined: 17 Nov 2009 Location: Beatrice NE Points: 373 |
Posted: 02 Sep 2016 at 9:32pm |
I am a ways from you but have a right hand plow with beam and some hardware. $75.00 se nebr. 402 223 5339.
AC1945WC
Posted: 02 Sep 2016 at 10:16pm |
Luckily I do have a factory Allis-Chalmers plow parts book. I was just thumbing through it yesterday to look for some of the parts associated with the framing. I will definitely give Wertz a call to see about the moldboards and shares. Thank you all for the insight.
AC1945WC
Mikez
Posted: 03 Sep 2016 at 7:50am |
Pritty sure we have some NOS. shares for right hand plow
davetheplowman
Joined: 26 Dec 2013 Location: SpringValley,WI Points: 140 |
Posted: 05 Sep 2016 at 6:39am |
Look for the part#s on the back sides. Post them so you can find the same ones.
D14,D15 series II,D17 series III & IV
AC1945WC
Posted: 05 Sep 2016 at 8:56am |
Is there any specific place they would be davetheplowman?
AC1945WC
davetheplowman
Posted: 05 Sep 2016 at 8:59am |
The back side of the plow shear and on the moldboard.
Down torwards the bottom on the back. It will start with a 309. It's a 6 digit number. |
AC1945WC
Posted: 05 Sep 2016 at 7:49pm |
The left share is a 308843 and the right share is a 308805. The left moldboard is a 308893 and the right moldboard is a 309212. I also noticed in my parts book there is a part number for the hook which I didn't think was separate and it is a 308818. Is the draw rod still possibly available at an agco dealer?
AC1945WC
Wayne180d
Joined: 08 Dec 2015 Location: Gilman, Il Points: 5946 |
Posted: 05 Sep 2016 at 8:22pm |
I have 70or 8 draw rods.
Wayne180d
Posted: 05 Sep 2016 at 8:23pm |
OOPS supposed to be 7 or 8
Wayne |
Mikez
Posted: 05 Sep 2016 at 8:30pm |
Only number we have card on is 308808 that's on the same page as 308805
Gerald J.
Posted: 05 Sep 2016 at 9:46pm |
Those are 325 16" bottoms, left and right. Shares that could replace the 308843 soft center steel include 309249 alfalfa soft center steel, 308846 solid steel, 309227 narrow cut deep suck solid steel, 308849 chilled iron, 309225 narrow cut deep suck chilled iron.
Shares that could replace the 308805 solid steel include 308802 soft center steel, 309248 soft center steel alfalfa, 323652 full cut deep suck soft center steel, 308838 solid steel narrow cut deep suck, 308808 chilled iron, 309223 chilled iron narrow cut deep suck. Draw rods 14 and 16" left and right are the same 314586. These all came from the plow bottoms book referenced above. Gerald J. |
CAMBIS
Joined: 19 Jan 2017 Location: oceanside, ca. Points: 1 |
Posted: 19 Jan 2017 at 7:41pm |
Still needing plow parts? I have excellent lefthand and might have extra righthand moldboards and shares.
AC1945WC
Posted: 19 Jan 2017 at 7:51pm |
Yes I do CAMBIS. I have kinda put off my search for a little while but I most certainly could use them. How much would you take for the moldboards and shares?
AC1945WC
Mikez
Posted: 19 Jan 2017 at 9:27pm |
Welcome to the forum cambis
Gerald J.
Posted: 19 Jan 2017 at 11:39pm |
There were several bottoms that would fit the plow frames. You need to identify the bottoms by part numbers on frog, moldboard, or plow shares. There was not a universal bottom for a B or C plow. Study AC Plows Parts 101 over in the knowledge forum, there are also links to a plow frames and a plow bottoms parts book to help in the identification process.
Gerald J. |
