Model E 20 35
Gerald Taylor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald Taylor Quote  Post ReplyReply Direct Link To This Post Topic: Model E 20 35
    Posted: 02 Sep 2016 at 7:09pm
Hi evey one. I have a model E 20 35 and would ike to know about the oil level. Is that the brass tap on the side of the housing? and what grade to put in the governor? Can someone also tell me what model carbie was origional on thease? Can you still buy one and does any one have after market parts? Regards Gerald
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 6:54am
Bump for the move to Farm Equipment forum
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 9:08pm
Oil level should be at least as high as the lower tap on the oil pan, but not over the upper tap.
They originally had either a Kingston L3 or a Wheeler Schebler carb depending on year and whether dual fuel or just gas. Norm Meinert has parts.  I'm pretty well out of spare carbs now.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 5:50am
Norm Meinert   815-865-5372 is your best bet for parts
The universal answer to all questions is yes, how much do you want to spend?
This page was generated in 0.107 seconds.
