WD electronic ignition
Jon NW Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon NW Iowa Quote  Post ReplyReply Direct Link To This Post Topic: WD electronic ignition
    Posted: 02 Sep 2016 at 4:58pm
If I switch my WD to electronic ignition can I still leave it at 6 volts?
Thanks, Jon
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 5:30pm
I'm not sure they make the electronic ignition kit for 6 volt but I would not risk putting a 12 volt kit into a 6 volt tractor. If I were you I would switch to 12 volt, it's overall so much better. I have been very satisfied with the Pertronix kit in my WD.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 5:53pm
Pertronix does make a 6 volt kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 6:22pm
yup, just make SUREyou get the CORRECT polarity unit ! Otherwise...poof, majic smoke will come out......and your wallet will be empty..
Jay
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 9:11pm
I have one in mine and it is 6 volt, been in about 12 years with no trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 10:17pm
We have the 6V PG kits in stock if interested. Have a kit in my Model B going on 16 years old now. Just treated it to a new cap n' rotor a couple years ago.  We sell a boat load of them. We have the 6VPG, 12VPG, & 12VNG kits in stock. These will work with the stock 6V coils. If you visit our website, we have a "How To" on there on installing an E.I. kit in a Model G with OEM 6V system.  Gives you an idea how easy they are to install....
Steve@B&B
bb-customcircuits.com
