3 pt arm question
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Topic: 3 pt arm question
    Posted: 02 Sep 2016 at 9:58am
Bet someone's had to deal with this but new to me....
I busted out part of the ball on my tractor lift arm that connects to the three point (its a Massey 231....family tractor so go easy!). It still works but thinking I should look into replacing....so do I look for a new ball and does it press in? Do I buy a replacement tip from tractor store and have it welded on or should I just replace the entire arm?
thoughts appreciated.
D17 Series 1
Allis B- 1939
Allis B- 1945
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 10:32am
Ive had that happen in the past, and I purchased the repair end that includes the ball, then cut the old end off and welded the new repair end on myself. Pretty easy job, just need to make sure the overall length of the arm stays the same, or the distance between the ball centers. Good luck.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
