HD6 track adjustment
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: HD6 track adjustment
    Posted: 01 Sep 2016 at 7:42pm
Does the HD 6 use grease to adjust? If not what tools will be needed? Thanks
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 8:24pm
The hydraulic track adjusters using grease were an option. If you do not have the optional track adjusters you need a track wrench. On the manual adjusters there are (2) 1/2" x 2" bolts that loosen the lock on the adjuster threads. Some of the yokes have grease fittings for the standard adjuster threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 9:24pm
thanks dozer
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 12:06am
You will need to put a 4 foot pipe on the end of the track wrench and if you have time give it a good soak with WD40 or similar after letting off the lock plate Dozer mentioned
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 7:31am
When I rebuilt the undercarriage on my 5 I drilled the clamps for grease zerks. Sure did solve the problem of adjusting the tracks.
