Rims
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Rims
    Posted: 01 Sep 2016 at 6:20am
I am looking to source lighter weight rims for my 190. I don't know what I am looking for really.
What are these from? Is the center adapter something someone makes?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 6:32am
Or these
Charlie
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 7:10am
Those centers are either clamp on or weld on. I tried the clamp on style and broke one the first. Time I pulled it. So I bought weld on from kenny's pulling parts and have been happy with them. There's also a guy that makes a wedge style but I don't know anything about them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 7:29am
U Bolt type Clamp on hubs MUST be tightened correctly or they will break. I've known people to break cast hubs on very low HP tractors and I've had factory M Farmall hubs on a modified with more than 600 HP.  Many companies made hubs for duals, M&W and Urvenworth are just a couple.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 8:05am
Wow, they are pricey!
3.25" axle clamp on hubs, $400 to 800!
Charlie
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 8:09am
Looks like a very standard 9 bolt dual hub to me.  Any salvage yard should have them laying around.
AaronSEIA
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 10:01am
I have a set of 3-1/4 9 bolt hubs for sale also a set of 18.4-38 wheels and tires. Pm me if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 11:12am
How's the correct way to tighten them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 7:25am
Evenly and slowly, like a head. If you get one bolt ahead of another it will surely break the hub. It won't matter if you buy the top quality hubs or the basic OEM hubs, improper tightening is a recipe for disaster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 7:47am
And re-checking the torque after a couple of runs, not just assuming they will stay tight. Cleaning all the paint off of the axle is a good way to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 7:51am
OK, I will look local and see what I can find
Thanks for the help.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 8:00am
There is also a difference in where the center disc is positioned on the rim when they weld it. Your top picture shows the disc more centered in the rim, while the lower picture is more to the outside. You generally want the tractor as narrow as possible for performance and hauling purposes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 9:24am
Not to hijack a thread, but why is narrower better for performance?  Clearly less stress on the axles, but other than that...
AaronSEIA
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 6:38pm
The narrower your wheels are set the straighter it should go. It won't try to turn your tractor as much when one wheel starts slipping. Also its easier to fit on a trailer when the wheels are set in
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 9:35pm
Where did you find that top picture Charlie? That is my oldest son pulling in Moses Lake WA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 5:22am
waterstractor.com
Cool! I have some questions about the tractor if you don't mind?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 6:18pm
no problem
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 6:40pm
Kevin here's a video of him pulling the top 190 load YouTube then put this in the search box. x4EJ-Ky_G9E
Edited by bradley6874 - 21 Sep 2016 at 6:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 7:06pm
Everybody puts their wheels in , gotta be different and move them out about a half tire witdth out ,,,, don't want to hit the holes the other guys did
