Low rider B question
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Low rider B question
    Posted: 31 Aug 2016 at 7:59am
Anybody on here ever drop a B before? Working on a B today that a guy wants dropped. Just wondering how the brakes are supposed to work and how the seat rails and all are suppose to be put together.
Can't fix stupid
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 8:14am
I think that the final drives are usually spun 180 degrees, and the left is switched with the right so the brakes work right.
That is what I have heard, someone else that has done it will probably chime in here soon....
'39 Model B
Tractors are cheaper than girls, remember that!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 8:16am
That's what I was wondeing if when I turn the finals if they need to be switched side to side as well. Then the question of the brackets/seat rails come in. Do those just get put on upside down also??...
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 8:24am
I am not sure, I had a page bookmarked that someone else on here had posted their 'slammed Allis B' (as he called it), but he has removed all the pictures so it might not help as much... but here is the link anyway....Slammed Allis B
I wish you the best of luck....Wink
'39 Model B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 10:07am
I saw a low rider B at the show near Madison SD a few years ago. I just found 4 pictures of it on this computer. Looks to me like the front axle was turned upside down, and the rear drop boxes were turned 90 degrees, turning 180 would probably get the belly dragging on the ground. I'm sure I've posted  these pictures on this forum before.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 7:27am
Okay, only 90 works for me, 180 might have a few ground clearance issues Smile
Learn something new every day!!
'39 Model B
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 9:01am
I lowered my B all the way. I have tons of pictures I can text you if you would like. Or if you would like to talk on the phone that's fine as well.
Send me a PM
Final drives get flipped 180 degrees and left to right so the brakes face forward. I welded on a small section of 3" angle iron to the NEW top of the final drive for the seat brackets to mount to. Seat still stays on top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 9:08am
Here is a link with some pictures.
http://www.allischalmers.com/forum/forum_posts.asp?TID=117265&KW=&title=pics-of-the-lowered-b-i-have-been-working-on
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 4:57pm
Its easy to make a link live, hit the icon to the left of the smiley face on the quick reply.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 11:56pm
Thanks for making it hot Gerald.
Dick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 9:42pm
I just finished my 3rd one
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 5:45am
Very Cool!!!!
Steve Wilkens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 6:11am
This is my lowrider. did 180 and redesigned the brake mechanisms. Flipped the brake bands around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 6:16am
another view
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 12:08pm
Gerald J.
just make sure there's only one instance of the  http://
as it already appears to the left of where you are inserting the link.
BTW, has anyone made or seen a lowered AC model other than the B ?
Given the final drive design, it looks feasible for many of them.
Edited by Gatz in NE - 29 Feb 2020 at 12:26pm
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 12:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 1:01pm
Steve
What I’m the world are those front wheels and tires off of and what size are they?? It looks pretty darn cool what ever it is!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2020 at 1:19pm
1932 Ford 18" wire
