190 no hydraulics
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: 190 no hydraulics
    Posted: 30 Aug 2016 at 9:26am
Got to play with our "new" series I xt this weekend. Originally we bought it for parts but now think we are gonna save it and make a loader out of it. It gets water in the engine oil but I've fixed 3 of those so far so not unfamiliar with that but it has no hydraulics at all. No lift drive or steering. Oil is full pump is quiet. Is there anything besides a pump that could cause this? Also we did get coolant running out of the bell housing or above when we winched it onto the trailer...is there a soft plug in the rear of block? I've never had a 301 completely out of frame...this one will be coming out as the rear seal is out of it.
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 8:13pm
Has anyone heard of a broken pump shaft? Haven't got it apart yet bet tractor
Lost all bus power at once...seems kinda odd
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 10:18pm
Pump has lost prime or striped splines from drive gear.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 10:44pm
It stopped on the previous owner while running a brush hog for a few hours so I doubt it lost prime so I guess I'll check the splines. I'll probably just wait till I pull the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 9:09am
Looking a littler more I found out the hyd level was near empty when it got hauled but my FIL had filler it before I got there. So I'd better make sure the pump has not lost prime....so how do I do that
