hd5 fan belt
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: hd5 fan belt
    Posted: 28 Aug 2016 at 8:41pm
does anyone have a part number for the fan belts on a 2-71 Detroit in a hd5? aftermarket part number is ok. thanks.
DavidnTenIll View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 8:47pm
TR 22625 Gates I believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 9:21pm
I used a B series belt - think a B58 - but then i have my machine modified with a Alternator for charging battery and a starter motor with solonoid so it's key start .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 8:45pm
THANKS FOR THE REPLIES. COLE, WHAT ALTERNATOR DID YOU USE WITH 2 PULLEY SLOTS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 8:47pm
SORRY, MEANT COKE.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 11:31am
I have a one wire delco like from a 80's pickup on mine.The shaft fits the double pulley that was on the generator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 11:53am
I took the pulley from a 78 GMC 427 truck engine alternator - 2 groove pulley - narrow belt - chucked in lathe and opened up to accept the B belt - bore of pulley fits any 10SI alternator and with small size and deep belt - it charges well.
 Cast iron pulley so easy to cut deeper and wider .
This page was generated in 0.166 seconds.
