new to me B-112
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: new to me B-112
    Posted: 26 Aug 2016 at 5:23pm
Finally got me a REAL garden tractor, a B-112.12Hp with hydraulic lift and 48" deck. Seems it's a 24 speed and has an 'odd' lift out back.
I'm looking for any links to get manuals and implement info. As I already have some cat0 3 point stuff(blade,1Fplow,cults) I'd like to use them..once I get her running .
Jay
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 9:31pm
http://www.simpletractors.com/Main/AC_models.htm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 5:38am
That odd lift is a sleeve hitch setup.  There is a "U" shaped bracket that pins in the bottom holes by the pin hitch.  That attaches to the implement with a pin.  Top large hole gets a rod that does the lifting.  If you Google sleeve hitch or Brinley hitch, you'll see how it works.  I suppose a cat 0 3 pt could be fabbed up, but it really wasn't designed for that style of hitch.
The 24 speed is a variable drive setup.  I guess it's a pretty temperamental setup from what I've read.  Go here:  https://www.simplicitymfg.com/na/en_us/support/manuals.html  and punch in the model number 990494 to get a free op and parts manual.  It'll be for the Simplicity version, but other that the seat and hood, they are identical.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 11:16am
Thanks Aaron...great I got RID of the sleeve hitch stuff eons ago when I got some 3pt Sears stuff....sounds like I'll need to fab a 'sleeve hitch -3pt adapter...
QUERY : does anyone know of a sleeve hitch to 3pt adapter, even a picture will help !
Thanks
Jay
Edited by jaybmiller - 29 Aug 2016 at 6:20am
This page was generated in 0.262 seconds.
