RC Tractor For Sale, Kerosene model
Larry Swenson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Swenson Quote  Post ReplyReply Direct Link To This Post Topic: RC Tractor For Sale, Kerosene model
    Posted: 22 May 2010 at 9:20am
For Sale:  Just arrived from Wyoming, factory kerosene RC tractor. Very few of the 5,500 RCs produced came in kerosene.  This tractor runs, but has WC wheels.  Price is $2950.00.
Located in south-central Minnesota.  507-787-2338.
briwayjones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briwayjones Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 5:44pm
Does Kerosene work with plugs like gas or compression like Diesel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 5:57pm
The way a kerosene or other low grade fuel burning engine works is you fill the main tank with kerosene and a smaller lawnmower size "Starting" tank with gasoline. The engine is started on gasoline and once warmed up the gas is turned off and the kerosene is turned on. A low grade fuel engine will normally have an intake manifold that is heated by the exhaust more so than a gasoline manifold. Because kerosene is much less volatile, it takes a hot manifold to help vaporize it so the engine can burn it efficiently. Low grade fuels also have lower octane so the engine will typically have a lower compression ratio to prevent pinging.
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 8:47pm
How rare is a RC with dual fuel, I have one in shed and thought that it was just a common option on the RC , thanks Mark
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 7:40am
Nice looking tractor - hope somebody gives it a good home. I'm sure it would be happy in my barn, but can't make it happen right now.
This page was generated in 0.044 seconds.
