Gleaner E3 traction drive belt
Joe Graunke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Graunke Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E3 traction drive belt
    Posted: 19 Aug 2016 at 1:20pm
Was wondering on the adjment for new traction drive belt what it needs to be set at
Thanks Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2016 at 4:52pm
Joe - I set mine as tight as I can make that "half moon" metal tension adjuster go.   Doesn't seem that tight to me.   Never have a slippage issue on my hills though.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2016 at 10:27pm
Adjust until there is 1/4" between shaves at bottom in slow position. Adjust, run to hi and back to lo until you have the 1/4".     MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2016 at 10:44pm
make SURE it doesn't run on the pins in high speed... or vibrate, which means slack in the bearing to shaft play or a brg down.
This page was generated in 0.307 seconds.
