Allis d262 diesel motor help required
rangertown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rangertown Quote  Post ReplyReply Direct Link To This Post Topic: Allis d262 diesel motor help required
    Posted: 16 Aug 2016 at 7:43am
I am currently restoring a allis dd grader fitted with the d262 diesel motor, i have comprehensively rebuilt the motor and when test running the motor before refitting it i noticed it has a loud heavy knock, i have  dismantled it twice now to locate the problem but no signs of any faults?
Has had full rebuild kit, pistons, liners, crank grind and matched big end shells, fuel pump and injector rebuild, head overhaul with new valves.
starts easily and has 35 psi oil pressure.
Any help would be much appreciated, thanks.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 12:56pm
Piston hitting head? Or valve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rangertown Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 3:32am
The sound seems to match that noise, but cant see any trace of it after removing the head.
This page was generated in 1.117 seconds.
