7020 charging system
mnjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnjoe Quote  Post ReplyReply Direct Link To This Post Topic: 7020 charging system
    Posted: 20 May 2010 at 7:57pm
My 7020 alternator light started to glow dimly this afternoon. Checked voltage..was 11 volts. Checked batteries some dead cells and others low on water. They have been giving me problems. Went to NAPA to get 2 new ones. Now my light stays off till I speed up the motor. Voltage is 13. Is my alternator also bad/ Thanks mnjoe
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 9:05pm
Check the ground on the alternator.  If that is good, go to the auto store and get a $10 rebuild kit for a delco 10si and put in new brushes and a regulator with new bearings.  I did that this past summer to my 7000.  Does your 7020 have a delco?  If not, then disregard the rebuild part.
Hurst
1979 Allis Chalmers 7000
5800 Hours
This page was generated in 0.062 seconds.
