Stuck valve on WC: Fix without pulling head?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Stuck valve on WC: Fix without pulling head?
    Posted: 15 Aug 2016 at 6:28pm
You guys out here are pretty creative... what is a good way of unsticking exhaust valve without pulling the head? I have tried sneaking pry bars in to lift up on the rotor to no avail.
It is a number 2 cylinder. I do have the tool to pull Keepers without pulling the head.
Edited by nowaktj - 15 Aug 2016 at 6:29pm
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 6:33pm
Is it stuck open or closed?
I've heard of guys who pull the valve cover, then hit the valve stem with a hammer, and that freed it up.
Edited by CrestonM - 15 Aug 2016 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 6:35pm
It is stuck open. It seems to be stuck hard. I wonder if it is bent.
Edited by nowaktj - 15 Aug 2016 at 6:35pm
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 6:36pm
you might do what we did with the big radial aircraft engines(2800 and the 3350).called staking the valves.remove the rocker amr,lube the valve stem with croil and tap the valve with a rubber mallet or a wood hammer.....
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 6:54pm
Grind the spring off and try to turn the valve with a vise grip.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 7:12pm
Take the tool you have and remove the keepers and spring. Then put some paint thinner in a squirt bottle and shoot some thinner on the stem and tap it with a piece of wood. You might put some tape around the very top of the valve so it doesn't fall down on the piston. As suggested Kroil is really good penetrant to loosen things up too.
WDDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 7:13pm
Might do more harm than good if it wont move with pry bars or vise grips.
   Any more than that you might damage the head if it is bent like you suspect.
   Might be more work but better and maybe cheaper in the long run to pull the head.
WD ,wide front, with loader
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 7:44pm
Once you pull the head and do a proper repair of the problem you will have lost the fear of removing heads on your tractor. Takes a couple new gaskets and maybe a valve and guide. Might just be a cleaning of the guide and stem.  Guessing can go on for ever. Even if you free it up you will still wonder why it stuck in the first place and will it do it again soon.  If you would get it freed up to where it opened and closed and it didn't seat properly it would then burn the valve as well as the seat.
Ya gotta love me now.LOL
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 9:26pm
    Yep,,Yep,,,you just gotta love a guy like ole Dick Lemmon,,,,,ClapClapalways got some good suggestions with tongue in cheek,,,,,,LOLLOL
   There IS one other suggestion,,,get you an old spark plug, break off the porcellin and weld a 1/4"  quick coupler on the spark plug. Remove all the spark plugs and install your new "tool" into the cylinder with stuck valve.  Make sure tractor is in neutral,,!!! .Remove valve cover and Hook your air hose onto the coupler. tapping on valve while air pressure is on cylinder "might" start moving the valve to the closed position. This should work to free valve unless,,,,,valve is bent,,in which case you are money ahead to pull head, cause you will ruin the valve guide tryin to force it outa there,,,,Hope this helps,,,,
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 10:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 11:02pm
take spark plug out turn piston down push around to feet of small rope in cyl' turn motor wear piston goes up should push valve up' lube it thin you can work it up or down pull rope out try it' worked for me lot's of times
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 6:48am
If its just stuck from sitting and not bent, the Kroil down the valve and the rubber hammer idea should work. I've used that technic many times over the years on Antique cars that had stuck valves. In most cases, once the penetrant gets down in the guide and loosens the varnish, the tapping at the top of the valve usually will pop it up. Keep the pry bars outta' there. They do damage. If the valve doesn't come up after some fussin' with it, it could be bent. Then its time to pick up a head set, remove the head and get the whole thing checked out at the machine shop... Good Luck!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 10:00am
What is the likelihood its bent? I'd say little.What would be the cause?Soak and tap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 10:08am
Had a neighbor that had a valve hang up on his lawn tractor. He juiced it up, did some monkeyin around and got it free, for a while. Every time it sat for any amount of time he seemed to have the same problem. A monthly ritual could have been ended with way less time and trouble by fixing the problem in the first place.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 11:58am
Pull the manifold and look at stem. Do not put anything in the cyc.
Piston can not hit valve to bend it with stock piston.
Edited by Fred in Pa - 16 Aug 2016 at 12:01pm
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 7:28pm
pull the damn head off and see what you are up aginst for certain.it is no earth shattering deal to pull the head.guessing and all the variables wont cut the mustard.....
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 8:15pm
It takes about 1 minute of fooling around to make the problem 1000 times worse, and much more expensive.  It takes about 20 minutes to remove the head, once the coolant is drained, and you can repair it correctly, and it will last.  May cost a bit more, but it won't stick again, if you keep it dry.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 8:33pm
I believe we solved the problem,orangeblood,sure is better than swolling a valve ,busting a rod,ruinening a head or a sleeve or possibly busting a crankshafh.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 7:48am
I am not sure I follow what you are tying to say.......
Are you saying, Shut Up OB, we got this handled, or are you agreeing with me.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 8:18am
   Now,,,now,,,Anthony,,,,,,,,,LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 8:22am
AMAZING
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 8:42am
The first wise guy don't have a chance! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2016 at 12:03pm
I finally pulled the head and the root cause was that the valve was simply stuck from sitting (tractor was sitting inside a dirt floor machine shed for ~3 yrs).   Without seeing this myself, I wouldn't have believed it how tight that vavle was.    Little more background...the engine was a donor that had appeared to have been rebuilt recently so the guides were maybe tighter than something with 2000 hrs on it. I also thing the rope trick would have worked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2016 at 2:51pm
The rope trick might have worked! Pulling the head did work though. What might have gone wrong didn't.  No sleepless night over this now. Good job!
I could write a book on the short cuts I have taken over my life time that went wrong.
That of course would depend on my learning to read and write. Or is it reed an rite!
Edited by Dick L - 22 Aug 2016 at 2:54pm
