Electric PTO Clutch Issue
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: Electric PTO Clutch Issue
    Posted: 13 Aug 2016 at 10:13am
OK what am I missing? The electric PTO clutch on my AGCO ALLIS 2020LC (Simplicity Legacy) lawn mower does not engage.
1. Replaced the switch and have power to the PTO Connector. A test light attached to the connector lights up when I activate the PTO switch.
2. Resized the air gap and checked Ohms on the clutch assy; talked to the service tech at Ogura (clutch Mfgr) and was advised that the clutch was defective since the Ohms was too high.
3 Bit the bullet and paid the $400 for a new clutch and I still have the same issue....the PTO clutch does not engage.
The spindles are free and can turn the blades by hand. So now I have a new switch and a new clutch and have not fixed the problem!
Edited by GregLawlerMinn - 13 Aug 2016 at 10:15am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 2:45pm
Check your ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 2:55pm
yup, bad or high resistance ground. I add a separate ground from EPTO mounting tab direct to battery, #14 wire is fine, only 4-5 amps being drawn.
Every E-PTO I've ever worked on and fixed  draws about 4 amps. So old school math.. 12 volts / 4 amps is 3 ohms. Easy to check if off tractor, connect one lug to battery, other to ammeter then battery. Just be sure DVM is set to 10 AMP scale  first . It'll make a nice, solid clunk 'pulling' in.
If the coil of the EPTO reads 'infinite' or 1999 , then it's open( no connection). either a break in the coil or more likely the connection to the connector. Both are repairable,depending on skill or wallet size !
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 4:11pm
Most electrical is either a open , direct short or a grounding problem - and ground is most likely problem . A test lite and a ohm meter - two basic tools - the scratching the hot wire is real old school and not a good test .
This page was generated in 0.532 seconds.
