rpm check |
Post Reply |
john2189
Silver Level Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 304 |
Posted: 20 May 2010 at 1:04pm |
HI if the pto shaft on a b is 540 rpms, does that mean that the motor is set at the proper rpms ? i think 1800 rpm.
John
'41 Allis B
'45 Allis B '49 Farmall Cub '72 IH Cub |
Hartland Farm
Silver Level Joined: 13 Sep 2009 Location: Tennessee Points: 86 |
A Allis Chalmers B with the BE engine is goverened at 1400 RPM. With the CE engine it is 1500. |
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
No, I believe the CA with the CE engine was rated at 1650 RPM. 540 Pto speed would be in there somewhere but full throttle might not necessarily give you 540 pto rpm's.
ALinIL
Orange Level Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
John - I believe the PTO is 600RPM at the rated 1500RPM rated engine. - AL
ALinIL
Bump - 560RPM at 1400RPM. - AL
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20945 |
If a "B" and a "C" are at 1400 engine RPM the PTO speed is 560........high idle(no load) of 1700 rpm would be 680 RPM at the PTO (if high idle is 1800 RPM, the PTO would be 720 RPM). The "CA" is 538 PTO RPM with the engine at 1650 RPM and that would yield 652 RPM at 2000 RPM (no load) engine speed.
Post Reply | |
