Paint Prep
HVFDFIREFIGHTER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Topic: Paint Prep
    Posted: 10 Aug 2016 at 6:10pm
Getting ready to put primer coat on. All wire brushed. What is the best way to get rid of oily residue?
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 7:16pm
I use one of these with lacquer thinner.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 7:17pm
Lacquer thinner works. They also make paint prep stuff that is a lot like lacquer thinner.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 8:46pm
Castrol SuperClean.  NAPA sells it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 9:14am
Mineral spirits. It has a longer working time than lacquer thinner.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 12:20pm
Castrol Super Clean goes by just Super Clean now. I bought 2.5 gallons for $18. It was sitting right next to another product called Purple Power. The net said both are good products but Super Clean is stronger. I got the Super Clean. I'll give it a try.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 3:24pm
I find when hanging small parts hitting them with brake cleaner right before painting is a lot less tedious and works better than wiping them with something. only thing is a can goes fast
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 5:39pm
VM&P Naphtha makes a good pre prime wash on metal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 6:21pm
Well I think tomorrow is the big day.  Got the tractor stripped down as much as possible.  All has been wire brushed and hit with the needle scaler, blown with air, and washed with Super Clean and air dried.  It is looking pretty good.
I have never used a HVLP gun before today.  Ran a lot of water through it today "painting" cement playing with air flow fluid flow etc.  I think I am ready to try some primer tomorrow.  It is a sandable primer so if I screw it up, I can take it off and try again.
Water sprayed good at 20 PSI with fluid nozzle open about 1/4 turn.  Had a nice elipticle pattern.  I am assuming paint will be a little thicker.  I have filters once I mix it.  I think it says 1 pint reducer for 1 gallon paint.  I am going to mix in smaller batches though.  Anybody have any tips?
Edited by HVFDFIREFIGHTER - 11 Aug 2016 at 6:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 7:04pm
I personally would use a self etching metal primer or epoxy primer on cleaned metal.
   Sandable primer surfacer is not designed for priming bare metal. Save it for a smooth sanding primer over body work and first prime. When you get a smoothed surface ready for finish paint seal it with a primer sealer before applying final color coats.
    You can't hardly do enough prep work before shooting final color coats.
Edited by Ken in Texas - 11 Aug 2016 at 7:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 10:24pm
I agree with Ken. For the first primer coat I'm a big fan of self etching primer. After that I'm OK with whatever primer you want to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 8:05am
Looks like a HF sprayer. Used several of those and also have an expensive one and even though they lay it down differently I'd be hard pressed to say the more expensive gun paints better than a cheap one from HF. You'll do fine.
1968 one-seventy
1956 F40 Ferguson
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 8:08am
I, personally, would wait until this terrible humidity in our area subsides, before spraying paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 11:27am
Well I am impressed with the HF gun.
Paint Booth:
Primer started
Primer complete
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 11:34am
Looks like you're making good progress!
I agree with the others, use a self etching primer on the bare metal. Then, if you want to get picky, prime again with sandable primer. I did spray on a layer of sealer over the primer before painting, but I don't think I needed it. Had some guys tell me the sealer is more to keep old color from bleeding through. When I painted my 45 a few years ago a barely used sanding primer. The expensive self etching primer laid on really smooth. I was getting tired of painting and decided it was good enough on most places. I don't have a perfect show finish, but it turned out pretty good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 1:05pm
I'm impressed with your paint booth!!
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 1:55pm
PVC pipe and 2mil plastic. 13'x10'x7' 8 3/4" 3 ways, 4 couplings, 12 10' 3/4" Pvc pipe, 20" box Fan on one end and furnace filter on other. Seems to work. Having trouble holding plastic to floor. Might have to wrap in 2x4. Sat 2x4 on top of plastic but it keeps pulling out. I'm guessing I should wait 24 hours before top coat?
Edited by HVFDFIREFIGHTER - 12 Aug 2016 at 1:59pm
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 3:28pm
Read the product Data.
some primer can be coated after 1 to 2 hours later some work better later also depends on the temp and humidity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 8:39am
I use brake clean, dries fast, leaves no residue, spray it on a rag and wipe down, painted an RC tractor with spray cans in 2003 after wiping down with Brake clean and it still looks good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 7:19pm
Primer was dry this morning.  Lightly sanded and put first color coat on.  Will check tomorrow ans see if it is ready for a second coat.  I noticed a lot of orange paint on the floor and on the corners of the walls near the floor.  Kinda hard to spray the under side of the tractor.  The angle of the gun just does not make it easy.  I like the results so far.
Edited by HVFDFIREFIGHTER - 13 Aug 2016 at 7:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HVFDFIREFIGHTER Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2016 at 1:13am
I am thinking two coats should be enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2016 at 6:21am
Looks good! I like your booth too.
Two coats should be fine, as long as they were 2 decent coats. I usually do a light duster coat at first, followed by 2-3 decent coats. Knowing when to walk away is an art.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2016 at 8:08am
Interesting, what kind of paint are you using that you wait so long for the second coat.
I always thought that you came back on with another coat when the previous one tacked up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2016 at 9:08am
That's how all the paint I spray works.
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2016 at 10:49am
Knowing when to walk away is an art. +1
That gets me every time- I want hit one last spot and the bam, it runs... Best to do several coats.   As you mentioned prior, the bottom is hard to cover good.
Edited by WC7610 - 14 Aug 2016 at 10:50am
Thanks
