better puller wc or wd45?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: better puller wc or wd45?
    Posted: 09 Aug 2016 at 4:23pm
Div 2, 3 mph class, built motor and 15.5s.
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 6:29pm
Well I pull two Unstyled WCs and even know you can do the same to both tractors Id say the 45 would be better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 7:13am
What weight? If you want to run 3000 a WC is the only way to go without lots of aluminum.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 7:22am
45 is geared lower than wc and with 15.5x38 a wc is pretty fast in first.  also a wc can be made lighter.  make sure you can run those big tires in the low weights with your rules,  NATPA only allows 15.5x38 at 4500 and up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 8:07am
I thought Div #2 didn't allow any "built" engines??????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 8:45am
"stock block, naturally aspirated"
 "original stock appearance"
doesnt matter whats inside lol
Edited by CAL(KS) - 10 Aug 2016 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 9:52am
I lean towards a "WD" straight stick transmission, which has a faster low gear than a WD-45. 3500 lbs on up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 10:18am
To clarify, a WC low gear is the fastest, WD straight stick is next (both of these were called 2 1/2 MPH @ 1300 and 1400 RPM's) and WD-45 is slowest at 2 1/3 MPH @ 1400 RPM. When you use 38 inch rubber, the difference is even greater between the 3 models, with the WD-45 still the slowest.
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 11:19am
What year did the WD go to the curve stick transmission? I have a 51 with a curve stick, but wasn't sure if the shifter had been swapped out.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 11:28am
Officially at chassis s/n 127,007 and up, is when the transmission design changed from sliding spur gear to constant mesh helical gear. Shift tower assemblies don't interchange between the two types of transmissions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 11:34am
Ahhhh...ok. Thanks Dr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 11:37am
S/N 127,007 translates in later 1952 I think.
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 9:41pm
Dr. I run a wc head but all ported and polished big valves. Would a 45 or d17 head do better cause it is taller. I would port it and put big valves in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 7:44am
I've always preferred the tall head because of the center-fire spark plug location. The porting/polishing on my two engines are very minimal, but I don't know why one couldn't replicate the same (or better) results that you have with the tall head versus the short head. I have one big valve head with 400 cubes and one stock valve head on 290 cubes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 5:26pm
Dr. My wc head has 1.92 big block Chevy intake and 1.62 exhaust. I did my own porting and polishing, KIETH Merfeld did my crank and he said he has never seen a small allis head opened that much he said my head is just fine. What horse is your 4oo cubes? We think it is around 110 hp. We hit 95 when drop box cracked, it was still pulling. I think if I did the same to a45 or d17 head I could get more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 6:09pm
Unless you have a flow bench I wouldnt waste your time. Without a flow bench you have no idea if you help or hurt yourself. If you do the same work to it its not going to make anymore hp just because it's a tall head. In my opinion it would not be worth the money or the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 6:49pm
20 or so years ago, I did two engines for two different people during the Winter months. Minnesota and Ohio were their destinations. Both were 362 cubes with identical parts and camshafts. One had stock valves and my usual minimal head work and the other already had big valves from a previous builder. Both had identical carbs. Both dynoed virtually the same HP. I always figured the small valve engine would lug down to the point where you could count the radiator fan blades go by and the big valve would have run better at 3,000 RPM. What did they dyno?? That's my little secret !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 7:43pm
The big valves should have a bigger carb. I will stick to my 110hp thinking. And if people ask I will say it has 226 cubes. Dr. U shouldn't keep ancient Chinese secret. Lol
joetom08 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joetom08 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 8:42pm
People would ask me how many cubes or you running.. I'd just say "all of them!" I like to brag about it but I liked people guessing about it more lol I'd say the same for horsepower
Edited by joetom08 - 11 Aug 2016 at 8:45pm
