how much Hp with bigger bore?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: how much Hp with bigger bore?
    Posted: 19 May 2010 at 9:54pm
261 cubes, 464carb 175 venturi, head opened slightly, Barney taylor cam,9-1 comp. What do you think that will make, the d19 262 was rated at 72hp. Do you think it will make that? Thanks,JM.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:56pm
it should make that but it may need more carburator than the 464 to make it. you did not post the bore size ? I know of a 241 cubic inch motor with a higher comp ratio that makes that easily but it has a bigger carb also.
Edited by mlpankey - 20 May 2010 at 8:03pm
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 9:09pm
It would be a 4.3 bore, pistons would be dished. Thanks,JM
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 9:13pm
with a dished piston it will definately need more carb especially if the dish is deep.
This page was generated in 0.050 seconds.
