D15 noise |
acdave
Topic: D15 noisePosted: 19 May 2010 at 9:15pm |
I bought my uncle's D15. It has a howling noise coming from the rear end. I remember it did this when I used to use it but it is worse now. It does it in 4th gear when it is pulling but not when it is going down hill. Any ideas?
Austin(WI)
Joined: 11 Sep 2009 Location: Wisconsin Points: 1472 |
Posted: 19 May 2010 at 9:23pm |
Do the Bull Gear Compartments have oil in them?
"Better By Design"
acdave
Posted: 19 May 2010 at 9:24pm |
Yes
DrAllis
Posted: 19 May 2010 at 10:06pm |
If every compartment is full of oil, it sounds like the typical ring and pinion gear whine(road gear only)....some are VERY noisey....and as soon as you crest a hill and remove the load the noise pretty much goes away.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 20 May 2010 at 6:20am |
My old D-15 did exactly what the Dr. describes, been told do not worry.
MikeSMN
Joined: 11 Sep 2009 Location: Granada, MN Points: 122 |
Posted: 20 May 2010 at 7:26am |
1964 D15 II - Acts the same way - only in road gear & only when there is a load on the drive train.
FredW
Joined: 12 Sep 2009 Location: N. Weston,OH Points: 588 |
Posted: 20 May 2010 at 7:40am |
Got one does it also. Fred
Austin(WI)
Posted: 20 May 2010 at 7:45am |
Mine actually does the same thing...just drove it yesterday.
"Better By Design"
