wd wide front bloster
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Topic: wd wide front bloster
    Posted: 19 May 2010 at 9:07pm
Does any one know how much a 3bolt and a 4 bolt bloster weight ???? Just the part between the frame rails. I have a corn picker coversion piece that weights 57# with the hubs. A early WC narrow front weights 120# don't know if i can get lighter than that. Also any one know how much a WD45 narrow weights ??? It is definatly heaverier than a wd one alot more casting to it.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:35pm
4 bolt bolster is about 175 lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:46am
Is that just the bloster or is it the entire wide front? I didn't think a 4 bolt would weight over 100# ..
