How much boost
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: How much boost
    Posted: 04 Aug 2016 at 6:28am
Will a stock 301 out of a 8010 take.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 7:45am
Dont know about stock, but 8 years ago the McKimm 180 twin turboed "Power Maxx" was leaving the line under 80 lbs of pressure.
AaronSEIA
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 8:21am
it will take as much as it can till it breaks...  maybe 30psi   right way put fire rings in the sleeves and forget about it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 11:06am
I'm making 40 pounds.
I think I will open the waste gate and keep her around 25
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 12:12pm
I have a 200 makes 60 psi boost and isn't fire ringed and a friend of mine is running a 190 with 80 pounds with out fire rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 1:18pm
200 allis are u runing factory head bolts and torque speck
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 4:10pm
Stock head bolts over torqued a Lil. Left rocker arm assembly off and torque with all short bolts. Then put rocker arm assembly back on and torque it down. Plugged block heater in over night and retorqued.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 6:50pm
The boost is a factor but not the only factor. How much power you develop is a much bigger deal. You can make 200 HP with 60 lbs. of boost or you can make 800 HP with 50 lbs. All depends on the setup. I would be certain that your connecting rods are hardened first. the softer OEM rods will bend before the head gasket blows if they are not heat treated.
I think a better way to describe performance is to give the weight of the tractor and in what gear you can spin it out - finish the run in. That is a more accurate way to describe how good the engine is and the stress that is applied to it.
Edited by O.P.S. Heads - 04 Aug 2016 at 8:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 7:24am
200 allis do u have hardens rods in ur engine and what weight class do u run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 9:34am
My rods are hardened but the 7000 series rods were harder then 3# series. I have been running 7500 and 8500
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 11:53am
On the 426 small pin rods, if they said JAPAN on them, there were better than newer generation rods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 12:49pm
I think I will just back my boost down some so i dont break any thing.
So what would it cost to get rods hardend
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 4:44pm
Max Simpson did my rods but don't think he is doing it any more. What timing u running makes big difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 4:48pm
Just under stock timing for this moment
This page was generated in 0.533 seconds.
